Thread: Oil Pan Gasket
Results 1 to 9 of 9
  1. #1 Oil Pan Gasket
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Alright so it's been some time since i have posted on here so i thought on my first post back i would ask the question if there is any easy way to change the oil pan gasket? from what i have red previously you have to drop the front part of the sub frame or pull the motor up a little with a hoist, does this sound about correct? because i really hope that there is an easier way to fix my problem but if not then, i guess i will just go threw all those step anyways because it has to get done
  2. #2 Re: Oil Pan Gasket
    Charles City, IA
    Support the engine from the top and drop the front of the cradle a little bit.
    SMGPFC Two Nipple General
  3. #3 Re: Oil Pan Gasket
    St. Louis
    alright thanks, it's been awhile since i have been under the car so let me see if i get this right. i'll have to un bolt the motor mount and then loosen the front 2 bolts on the front of the sub frame, and the tranny mount as well?
  4. #4 Re: Oil Pan Gasket
    Charles City, IA
    The tranny mount can stay connected IIRC. Been over a year since I have done one.
  5. #5 Re: Oil Pan Gasket
    Apr 2009
    stockton ca
    Seeing as i have close to half a quart of oil under my car right now I may be doin the pan gasket aswell I might get lucky and it may be the oil pres sensor
    SOme jack off stole my jack and ramps last month so havent been able to check yet
  6. #6 Re: Oil Pan Gasket
    Donating Users flower50's Avatar
    Jun 2010
    OHIO
    were is the oil pressor sensor located
  7. #7 Re: Oil Pan Gasket
    find your oil filter and follow the piece it screws into back to the block. Right on that piece on the rear of the engine is the pressure sensor.
  8. #8 Re: Oil Pan Gasket
    Wichita, KS
    I support the engine form the top, and drop the entire subframe/engine cradle out of the car. That way I dont have to work around, or fight the cradle being in the way at all.
    I prefer to do THAT job right the first time, unlike GM. LOL
    ~F~
  9. #9 Re: Oil Pan Gasket
    Dec 2011
    MO
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    I realize this thread is 13 months old but I think it makes sense to post here instead of starting new.
    Hi; I looked at changing the oil pan gasket on an 04. Did you disconnect the lower control arms before dropping the cradle?
  1. Lim gasket
    By cardiffGIANT98gtp in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 11:21 PM
  2. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  3. gasket kit
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 04:39 PM
  4. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
  5. LIM gasket
    By gtpinsc in forum General Tech Discussion
    Last Post: 10-21-2008, 03:37 AM
