Thread: Coil pack question
Results 1 to 4 of 4
  1. #1 Coil pack question
    Feb 2010
    TN
    My coil packs have rust on the terminals I have two questions;
    1.) Can I just sand the rust off them
    2.) Is there a way to test the packs and see if they are still good?
    I replaced them with MSD's but am seeing where the original coil packs are better BTW they have 300,000 miles on them if it matters, thanks guys
    Logan
  2. #2 Re: Coil pack question
    wire brush and then di-electric grease on the terminal.
  3. #3 Re: Coil pack question
    Omaha, NE
    Yes you can sand the rust off, use petrolium based terminal sealer like the parts store tells you to buy in those dollar packages when you get plug wires on them after to prevent future rust. If you don't have a misfire code, the coils are more than likely still good.
    If you're worried about it, you can get new ones for $15 each from rockauto.
  4. #4 Re: Coil pack question
    Feb 2010
    TN
    Thanks guys
  1. MSD blaster coil pack question
    By JoelW98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2012, 09:11 PM
  2. coil pack
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-13-2010, 12:22 AM
  3. Sluggish after coil pack install
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2008, 05:31 PM
