Hey guys!! Sorry it's been so long since I've last replied, I've been extremely busy, and a little disheartened after I did all of that work and nothing came of it . I finally found some time to take my grand prix over to autozone to not only get the scan done but actually have the receipt printed out for me!
Slowna06 I will definitely try those things you've said, thanks for all that information.
Here is what they printed out for me.
Troubleshooting: p0300
Oem Brand: Domestic
Definition: Cylinder misfire detected.-random cylinders
Explanation:
The powertrain control module monitors the crankshaft speed and has detected a misfire condition.
Probable cause
1. Ignition system fault-spark plugs ignition wires, coil (I've changed all of those!)
2. Vacuum leak
3. Injector fault
4. High or low fuel pressure.
Thank you all for your help so far! I'm hoping I can get more so that I can understand what this all means and what to do next. I'm kind of excited and re motivated to work on the car and get it fixed so I can finally drive my baby again.
Oh and the guy at autozone told me to spray brake cleaner (or fluid? can't remember) on the vacuum hose while the engine was running, and if the car died, than the problem is the vacuum leak. Does this sound right to you?
