Thread: im tired of this stupid gas milage!!!
Results 1 to 6 of 6
  1. #1 im tired of this stupid gas milage!!!
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Right now im getting around 260-280 Miles/tank. I was getting close to 400 miles/tank. I have no idea what it could be. I have replaced the plugs and wires, have open cone filter, replaced the Idle air control sensor (when i first got it), new fuel filter, new tires and alightnment, new filler neck for gas tank. and seafoam in the cylinders and gas but not the crank case.
    now. I had an SES light on. codes were for an o2 sensor, iat, coolant temp, and misfire. but the SES light went of and has stayed off. Should I replace all of these?
    Another question. The vacuume kit from zzp, does it come with the plactic fittings, or do you just push on the line (on the metal fitting on like the TB)?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: im tired of this stupid gas milage!!!
    Jun 2011
    Detroit, MI
    Gas mileage should go a down a little in the winter, but a bad o2 sensor is going to make it run rich/lean possibly causing the misfires. Replace the o2 and iat sensors and clean the coolant temp sensor or replace it. See what happens then.
    iLoveSpade
  3. #3 Re: im tired of this stupid gas milage!!!
    Jul 2011
    Michigan
    ooooo....missed the question there. just becuase those codes pop up, doesnt mean the stuff is actually bad. It may be a vacuume leak which will cause multiple codes to go off.
    i was asking if i should replace them sensors even thought the ses light is already off. and i would like some info on the zzp vacuume kit...pretty please lol
  4. #4 Re: im tired of this stupid gas milage!!!
    Jun 2011
    Detroit, MI
    THere would be no need to replace them if they aren't broken. Find you vac leak, cause its probably whats causing your starting issues as well.
    iLoveSpade
  5. #5 Re: im tired of this stupid gas milage!!!
    Sep 2011
    MI
    The seafoam can cause a couple of those codes(especialy the 02). I wouldn't worry about it unless they come back on. Cone filter hurts mpgs in the winter. the cold is the biggest factor. warming the car up to defrost windows ect... and the fact that the car will naturaly use more gas when its cold out.
    As far as the question about the zzp product... email them. they are pretty fast with their replies...
    you'll more than likely get your mpgs back come spring... just the way of it... always get a lot of people in the shop worried about the loss of mpgs come winter.
  6. #6 Re: im tired of this stupid gas milage!!!
    Jul 2011
    Michigan
    well....i probably should have said it. but i have been getting bad gas milage the whole summer/fall.
  1. bad gas milage
    By wilder9032 in forum General Tech Discussion
    Last Post: 03-15-2011, 06:29 AM
  2. Gas Milage???
    By ckrummy in forum Off Topic Discussion
    Last Post: 06-16-2010, 04:51 PM
  3. Fuel Milage
    By jdkopveiler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-19-2009, 10:37 PM
  4. ZZP HV3 intake milage
    By MnRedGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 06:02 PM
  5. Gas Milage
    By Hamm61 in forum Off Topic Discussion
    Last Post: 08-19-2008, 01:24 PM
