Thread: ZZP HV3 intake milage
Results 1 to 10 of 10
  1. #1 ZZP HV3 intake milage
    Jan 2009
    Eagan Minnesota
    I seen several have installed these and it seems most love the power gains. I plan to replace the gaskets on my 01 this spring and I am thinking about installing the HV3 plenum and a new UIM. However I can't find any information for mileage gains or losses . Doe the HV3 improve mileage or does it make it worse ? There is some great information as to what I need to order but if I take a hit on mileage I don't know if I want it. Any info would be appreciated. Thanks!
  2. #2 Re: ZZP HV3 intake milage
    Barksdale AFB, LA
    I doubt it really has any effect on mileage. Most who have it probably see less as their foot gets heavier.
    2009 Subaru Impreza WRX STI
  3. #3 Re: ZZP HV3 intake milage
    Jersey
    x2^ I really can't see why you would loose alot of gas mileage, its just an insert. It's not like your bolting up a s/c or turbo.
    16' wrx sti- stock
  4. #4 Re: ZZP HV3 intake milage
    TDCRacing
    Guest
    The HV3 is suppose to provide a better path to give better flow to the LIM.
    Well porting and polishing does the same thing. And it decreases fuel effeciency.
    Just a thought. I'd have to say if it did make any difference that you would not notice it more than likley.And agree with sabrewings.
  5. #5 Re: ZZP HV3 intake milage
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by TDCRacing View Post
    Wait, what? How?
    2001 Buick Regal LS - Almost Stock
  6. #6 Re: ZZP HV3 intake milage
    TDCRacing
    Guest
    Quote Originally Posted by Scimmia View Post
    Wait, what? How?
    Polishing the intake will reduce the rough cast layer and therefore decrease low rpm torque but will improve high RPM power. This is generally bad for mpg. It's the same if we had longer intake runners. Or a carubrator spacer or high rise manifold on a carburated setup. It raises peak RPM power.
    More power but less fuel economy.
  7. #7 Re: ZZP HV3 intake milage
    QCA, IA
    The HV3 is actually shortening the intake runners, though, not making them longer.
    Polishing the intake runners won't decrease low RPM performance. Opening up the runners a bunch will loose intake velocity, which WILL shift the power band up, but a basic port/polish won't.
  8. #8 Re: ZZP HV3 intake milage
    TDCRacing
    Guest
    Well true. If you consider the entire length of the stock runners. Wich I guess you would.
    If heard different info than what you have mentioned. But I think we share the same opinion that you wont actually notice any notable differences in MPG's.
  9. #9 Re: ZZP HV3 intake milage
    QCA, IA
    The HV3 could lower volumetric efficiency, which could potentially affect MPG, but I agree, I seriously doubt it's to any measurable degree.
  10. #10 Re: ZZP HV3 intake milage
    Jan 2009
    Eagan Minnesota
    Thanks for the responses. Sounds like it's a worth while mod if I' doing the gaskets anyway.
  1. intake....
    Last Post: 04-25-2010, 01:41 AM
  2. Gas Milage
    By Hamm61 in forum Off Topic Discussion
    Last Post: 08-19-2008, 01:24 PM
  3. Intake Q
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2008, 02:35 PM
  4. Intake/??????
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-28-2008, 03:05 PM
  5. Intake for 97 GTP
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 03-04-2008, 05:19 PM
