Thread: 99 gtp starts then dies..
Results 1 to 5 of 5
  1. #1 Re: 99 gtp starts then dies..
    Nov 2011
    south carolina
    The outgoing power from fuel pump relay doesn't go straight to the fuel pump. It goes out through a fuel pump resistor and then back up to the f/pmp spd cont relay. I think its right beside the f/p relay. So the f/p relay would be hot at the #30 terminal goin out and the f/p spd cont relay would be hot at #87A goin in. Could be the resistor.
  2. #2 Re: 99 gtp starts then dies..
    You'd want to test power going to the pump before changing a pump. Nacho his it on the head when he asks about the fuel pump speed resistor. When the key is turned the car primes. Then that pressure in the line will bleed off like you mention unless the pump kicks back on. This is very common.
  1. Car starts then dies
    By Rocket468 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 01:08 AM
  2. 97 gtp starts but dies
    By 50trimomni in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2010, 04:20 PM
  3. Car starts then dies
    By silver2000se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2010, 06:33 PM
  4. Starts then Dies!
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-29-2010, 08:42 AM
  5. starts and dies
    By betsgtp in forum General Tech Discussion
    Last Post: 11-30-2009, 08:56 AM
