Thread: Re-installing Door Window!!!
Results 1 to 9 of 9
m0ng00se Re-installing Door Window!!! 08-05-2008, 08:00 PM
SahotaGTP Re: Re-installing Door... 08-06-2008, 02:26 AM
Zef_66 Re: Re-installing Door... 08-06-2008, 08:27 AM
03GPScottyd Re: Re-installing Door... 08-08-2008, 08:43 AM
m0ng00se Re: Re-installing Door... 08-07-2008, 06:10 AM
Zef_66 Re: Re-installing Door... 08-07-2008, 08:50 AM
m0ng00se Re: Re-installing Door... 08-07-2008, 03:30 PM
Zef_66 Re: Re-installing Door... 08-08-2008, 07:08 AM
03GPScottyd Re: Re-installing Door... 08-08-2008, 08:45 AM
  1. #1 Re-installing Door Window!!!
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    Okay, recently my window regulator/motor broke and i had to order a new one. I didnt want my glass to be inside my door so i took it out while i waited for the new regulator to arrive. Now that it has came i installed it, but now i cant get the window back in!! I've gotten it into the door but i cant get it in the tracks at the front and rear of the door!!!!
    Any tips for getting this done? I've been trying for 2 hours now and finally had to quit.
    Thanks in advance,
    -Ryan
  2. #2 Re: Re-installing Door Window!!!
    no idea about the window but my cord broke off yesterday howmuch the motor go for
  3. #3 Re: Re-installing Door Window!!!
    PA
    When I did mine on my 2 door, I had my wife help. She was on the outside of the door, I was on the inside...with the door open and the panel off. I tilted the front of the window down a little, and got the rear corner into the track. Then got the front corner into the track, and tilted the window back straight again, making sure the gasket didn't get caught. Done this a couple times, and works fine.
    2001 GSE
  4. #4 Re: Re-installing Door Window!!!
    Louisville, KY
    Quote Originally Posted by SahotaGTP View Post
    I think Ed charges somewhere in the $40.00 area. Did the cord itself break or did the plastic holder where the chord locks in break. You shouldn't have to buy a whole new motor or regulator if that's the case. Go to the junk yard and pull a cable or the broken plastic piece you need. Will cost you $5.00 and then you can reinstall.
    There is a writeup in the how to section which will show you the trick for reinstalling the cable to the regulator. Done it 4 times now on different vehicles and it took me 2 vehicles to figure out the secret. Also if you use the writeup take pictures at each step and send them to the author of the thread to insert into the writeup.
    My Cardomain
  5. #5 Re: Re-installing Door Window!!!
    Jul 2008
    BFE, Kentucky
    That just sounds way too easy. I just cant seem to get the window to fit on both tracks and go into the door, but i will definately give it that a try and see how it goes.
  6. #6 Re: Re-installing Door Window!!!
    PA
    Quote Originally Posted by m0ng00se View Post
    It is pretty easy once you figure it out.
    The window needs to be down almost all the way into the door. It is much easier to get the window set in the tracks when it is in the door. And again, this is on a 2-door car. I never worked on a 4-dr...
    2001 GSE
  7. #7 Re: Re-installing Door Window!!!
    Jul 2008
    BFE, Kentucky
    I had it in the door at one time but it seemed impossible to get it on one track once it was on the other. :S Its like some kind of puzzle game.
    And btw, mine is also a 2 door
    Edit: Tried Zef's strategy and voila, it now works
    Just had to have someone hold it while i pushed and pulled it into the tracks. Thanks zef
  8. #8 Re: Re-installing Door Window!!!
    PA
    Hey, anytime. Glad you got it!
    And yes, having two people does help. I know I have done it by myself. But it is a pain.
    2001 GSE
  9. #9 Re: Re-installing Door Window!!!
    Louisville, KY
    If your really determined to buy a whole new setup, send me the used parts. I'll pay shipping...
    My Cardomain
  1. installing LOC
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2008, 12:08 PM
  2. trouble installing halfshaft
    By ShouldaGotTheGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-10-2008, 05:14 AM
  3. Installing rear rotors
    By wipeout48 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2008, 11:25 AM
  4. Installing HUD?
    By retski420 in forum General Tech Discussion
    Last Post: 03-17-2008, 02:29 PM
