Thread: Re-installing Door Window!!!
Results 1 to 9 of 9
m0ng00se Re-installing Door Window!!! 08-05-2008, 08:00 PM
SahotaGTP Re: Re-installing Door... 08-06-2008, 02:26 AM
Zef_66 Re: Re-installing Door... 08-06-2008, 08:27 AM
03GPScottyd Re: Re-installing Door... 08-08-2008, 08:43 AM
m0ng00se Re: Re-installing Door... 08-07-2008, 06:10 AM
Zef_66 Re: Re-installing Door... 08-07-2008, 08:50 AM
m0ng00se Re: Re-installing Door... 08-07-2008, 03:30 PM
Zef_66 Re: Re-installing Door... 08-08-2008, 07:08 AM
03GPScottyd Re: Re-installing Door... 08-08-2008, 08:45 AM
  1. #1 Re: Re-installing Door Window!!!
    no idea about the window but my cord broke off yesterday howmuch the motor go for
  2. #2 Re: Re-installing Door Window!!!
    PA
    When I did mine on my 2 door, I had my wife help. She was on the outside of the door, I was on the inside...with the door open and the panel off. I tilted the front of the window down a little, and got the rear corner into the track. Then got the front corner into the track, and tilted the window back straight again, making sure the gasket didn't get caught. Done this a couple times, and works fine.
    2001 GSE
  3. #3 Re: Re-installing Door Window!!!
    Louisville, KY
    Quote Originally Posted by SahotaGTP View Post
    I think Ed charges somewhere in the $40.00 area. Did the cord itself break or did the plastic holder where the chord locks in break. You shouldn't have to buy a whole new motor or regulator if that's the case. Go to the junk yard and pull a cable or the broken plastic piece you need. Will cost you $5.00 and then you can reinstall.
    There is a writeup in the how to section which will show you the trick for reinstalling the cable to the regulator. Done it 4 times now on different vehicles and it took me 2 vehicles to figure out the secret. Also if you use the writeup take pictures at each step and send them to the author of the thread to insert into the writeup.
    My Cardomain
  1. installing LOC
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2008, 12:08 PM
  2. trouble installing halfshaft
    By ShouldaGotTheGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-10-2008, 05:14 AM
  3. Installing rear rotors
    By wipeout48 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2008, 11:25 AM
  4. Installing HUD?
    By retski420 in forum General Tech Discussion
    Last Post: 03-17-2008, 02:29 PM
