Quote Originally Posted by 1986c10 View Post
Okay thanks for the info, i need to check that because it was only idling after jumping it then i turned it off. were the control arm bushing bad to do or pretty straightforward? thanks for the input
just change the whole arm, 3 bolts pretty much, start spraying the bolts with penetrating oil for a few day before you start the swap.
