Thread: Battery keeps dieing
Results 1 to 16 of 16
  1. #1 Battery keeps dieing
    SE Level Member 1986c10's Avatar
    Nov 2011
    Kalamazoo Michigan
    Hi, snagged a 97 coupe gt grand prix for 300 bucks that needed an alternator. replaced alternator, jumped it and it ran good, stayed running and no problems at all. let it sit for a week fired right up. tried to start after a week of sitting, no cranking at all, no interior lights turned on or nothing. jumped it for a long time and it finally started so i let it run for 10 minutes. tried to start it this morning and it was completely dead. battery isnt that old. Any suggestions? Thanks
    1997 grand prix gt coupe dual flowmasters
    1982 chevy c10 full roller forged 355, 12 bolt rear
    1986 chevy c10 lwb no engine
  2. #2 Re: Battery keeps dieing
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    batt grounding maybe?
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: Battery keeps dieing
    did you check the voltage at the battery and at the alt?
  4. #4 Re: Battery keeps dieing
    Omaha, NE
    Check the grounds and wiring.
  5. #5 Re: Battery keeps dieing
    Nov 2011
    Kalamazoo Michigan
    definitely sounds like a battery ground to me too now that you mention. where does the ground go on mine? i know on my truck it goes to the alternator bracket...
  6. #6 Re: Battery keeps dieing
    Nov 2011
    Kalamazoo Michigan
    havent checked voltage. another thing, the negative i believe cable part is kind of torn so is it possible that these old battery cables are junk and corroded and could be the problem?
  7. #7 Re: Battery keeps dieing
    GTP Level Member
    Oct 2011
    Raleigh, NC
    parasitic drain ? check current draw while sitting everything off
    or disc battery cable overnight and then see if it still starts
    1997 Red GTP 182000 miles stock
  8. #8 Re: Battery keeps dieing
    Nov 2011
    Kalamazoo Michigan
    i'll be sure to do that because that is definitely what it is. found alot of things i didnt want to looking for a grounded wire. probably about 20 cut wires with copper exposed in the engine bay and going to the cd player (which doesnt play of course). taped them all up, pulled the fuses for the cd player. positive cable of the battery cable was mostly exposed so i fixed that. right rear shock mount area has the metal around it broken. front shock mounts are broken. control arm bushings shot and a ton of other things. i'll check tomorrow to see if i cured the problem
  9. #9 Re: Battery keeps dieing
    best to just replace the battery cables, once the rubber is torn back and the wires turn dull looking vs the nice fresh shiny striped wire. it gets what is known as dry wire, they don't pass a current well any more.
    and if the car is not on the road and just sitting, a 10 minute idling wont charge the battery up enough to last to next week if its going to just sit.
    put the battery on a charger for a day, then start the car test the volt at the bat while its running, then turn the car off and test the battery's volts with car off, off should be at least 12 volts, running up to 14 is ok, but no less than a hi 12.
    ps: i just got a pair of dorman lca's from partsgeek.com for 97 bucks shipped.
  10. #10 Re: Battery keeps dieing
    Nov 2011
    Kalamazoo Michigan
    Okay thanks for the info, i need to check that because it was only idling after jumping it then i turned it off. were the control arm bushing bad to do or pretty straightforward? thanks for the input
  11. #11 Re: Battery keeps dieing
    Quote Originally Posted by 1986c10 View Post
    just change the whole arm, 3 bolts pretty much, start spraying the bolts with penetrating oil for a few day before you start the swap.
  12. #12 Re: Battery keeps dieing
    Nov 2011
    Kalamazoo Michigan
    thanks alot. i will be doing that next, i priced it out on rock auto, i think i can replace both arms and all bushings for like 150 bucks. Is the front shock mounts that are seen in the engine bay called the front upper shock mounts? because i cant find them on the site...
  13. #13 Re: Battery keeps dieing
    try out partsgeek.com, i just got both sides for 97 shipped to my door. dorman stock replacements.
    i think your talking about the upper engine mounts, they sell polly upper mount bushings for them, if your engine is moving a lot, take a look at your engine and trans mounts, they will let the engine move a lot if they are bad.
  14. #14 Re: Battery keeps dieing
    St. Louis
    If you aren't referring to the engine mounts, perhaps you mean the upper strut mount? The thing that sits in the middle of the shock tower w/ the large nut in the center?
  15. #15 Re: Battery keeps dieing
    Nov 2011
    Kalamazoo Michigan
    sorry i meant the strut mounts. if i push down on the car, the nut will move about 2 inches up out of the hole on each side. I'll try out parts geek
  16. #16 Re: Battery keeps dieing
    strut mounts are cheep, it just that you need to take the spring off and take the strut apart to change it, i had a local shop change the mounts, they charged 30 for the pair, the mounts were like 30 each im thinking.
  1. Car dieing
    By robbinsjr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2011, 09:50 PM
  2. Car bogging down at launch and dieing
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-18-2010, 08:46 AM
  3. Getting a car battery
    By Warbeaver in forum General Tech Discussion
    Last Post: 05-31-2010, 06:11 AM
  4. Help GT keeps dieing and grinds when starting and running!!
    By Panto911 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2009, 11:22 PM
  5. Random dieing at idle + occasional misfire = me pissed off
    By mark455 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 09:22 PM
