Thread: Taking forever to warm up
Results 1 to 20 of 20
  1. #1 Taking forever to warm up
    SE Level Member Moe Dubs's Avatar
    BC Canada
    2005 GP, takes +10 minutes for somewhat warm air to start blowing out of vents. Has gotten worse every year, I was told last year that GP has 2 diff thermostats and that I should get the hotter one? Heat worked fine the first few years, now I never get heat since I rarely drive for more then 15 minutes at a time.
  2. #2 Re: Taking forever to warm up
    GT Level Member mkyota1's Avatar
    Daytona, florida
    It sounds like the thermostat is stuck open. I would recommend replacing it with a new one. The factory temp range should be fine.
  3. #3 Re: Taking forever to warm up
    coolant flush, heater core flush and new thermostat should fix it.
    I recommend the coolant flush if its never been done before, otherwise replace the thermostat and bleed ALL the air out.
  4. #4 Re: Taking forever to warm up
    TWO t-stats?
    lol, no.
    Just one...in the lower intake manifold.
    Get a Fail-Safe 195* T-Stat and be done...since your car is stock.
    Have the dexcool flushed out and replace it with green or yellow crap...cheaper, works the same if not better...and doesn't gunk up like Dexsludge.
  5. #5 Re: Taking forever to warm up
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    My '04 was doing that. Replaced the thermostat, issue resolved. It had also started throwing the occasional engine too cold code, but the lack of heat was evident before this. +1 on the flush while you're at it.
    I think by two stats he meant there was a 180* available and the standard 195* one. Not two installed in the car.
    2004 GT2 Leather, Sunroof, heated seats, other stuff, but only a little DIC. Also, Kawi Vulcan 2000 http://tinyurl.com/ophidia
  6. #6 Re: Taking forever to warm up
    BC Canada
    OK thanks guys, just read my sleepy post. I meant someone told me last year that there were 2 available for the car, will replace and flush
  7. #7 Re: Taking forever to warm up
    Omaha, NE
    I would reccomend NOT getting a "Fail Safe" They tend to have a lot of issues with sticking open compared to pretty much any other T-stat.
  8. #8 Re: Taking forever to warm up
    BC Canada
    So I'm finally taking car in to get this looked at, going to try to not sound like an idiot at shop. This is what I intend to say when I get there
    "Car wont heat up, even after driving for 20 minutes or more it never blows hot air, just gets to kind of warm. Think its the thermostat stuck open and maybe needs a cooalnt flush, whats the cost?"
  9. #9 Re: Taking forever to warm up
    Pennsylvania
    I'm wondering if everyone is misunderstanding your problem.
    Is the engine refusing to get warm? You're complaining about the HVAC and haven't said a thing about the engine temp. Want to be clear on this.
    If your engine temp is fine, maybe your blend door actuator is smoked. Or air in the heater core.
    http://www.grandprixforums.net/blend...ent-21941.html
  10. #10 Re: Taking forever to warm up
    BC Canada
    Got my Qoute from shop, they say its a domino effect of problems and want to change my water pump, thermostat and a flush. Total cost after tax is $757!! $245 for water pump which I dont think is the issue, $201 for the flush and $95 for thermostat change and the initial $85 to have tech take a look at it... price seems outragiously high to me. I have had zero issues with car since I bought it in 2006, should I give the go ahead to to the thermostat and flush and say leave water pump alone? knocks $250+tax off total.
  11. #11 Re: Taking forever to warm up
    Pennsylvania
    $95 to change thermostat? It's an $8 part and I could do it without using my hands in about six minutes.
  12. #12 Re: Taking forever to warm up
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    It sounds conceivable that it's the water pump, it's not a $750 job. Take what they told you and get a second quote. Even a dealer wouldn't charge those prices. I did the same stuff on my old 3800 for around $100, and a few hours of time.
  13. #13 Re: Taking forever to warm up
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Get yourself one of those 20 dollar heaters you plug into the cigarette lighter. that way you can leave the heat off and you engine will warm up a little faster.
    and yeah, $95 is ridiculous for a stat change.
    I have found the quickest way to warm up is to drive around in second gear for a few minutes. I certainly wouldnt try it on the highway, but if youre keeping it under 40, that will warm you up a little quicker too. I also dont turn the heat on until the needle reaches the bottom line (140 degrees)
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  14. #14 Re: Taking forever to warm up
    BC Canada
    spoke in detail with tech, says water pump is leaking bad. which explains the swooshing sound ive been hearing and the orange spot in my drive way. Getting that changed since I have no idea how. After thats done going to attempt a stat change with some guys from work, they got me for $90 to tell me what is wrong. I really need some mechanically inclined friends in town
  15. #15 Re: Taking forever to warm up
    Quote Originally Posted by Moe Dubs View Post
    water pump cost 40 bucks, and 1 hr of your time tops. t stat 8 bucks, a gallon of coolant 15 ish.
    may i suggest you never let that shop work on your car, they are full blown thief's. and even 90 to look it over it to damn high.
    love this movie.
    Exactly what Scotty said. Parts needed are really cheap and you can do it yourself. Shop is taking advantage of you.
    04 Comp G.
  17. #17 Re: Taking forever to warm up
    BC Canada
    Looking for a cheaper place to flush, someone suggested Wal-mart... do you think their shop would do it correctly? Guy says thermostat seems to be working fine. Thinking of just changing it anyway with some guys from work who have done it before to supervise.
    If that doesnt work would it be a heater core problem, if so how long of a job should it be to replace it? Have some names to call of guys who do side jobs out of thier shops at home.
  18. #18 Re: Taking forever to warm up
    flush it yourself.
    take the t stat out, then put the housing back on, take the upper hose off the rad, start the car with a garden hose in the rad cap hole, run it till clean water comes out the upper hose.
    the take the hose out, run the engine till nothing comes out, put the t stat back in, add one gallon of coolant (not the 50/50 stuff, full strength ) top off with water, and bleed the air out.
    your heater core, take both hoses off the engine, take a garden hose to one of the core hoses, and flush it, then fill it with water. hook it back up.
    your cost, 15 bucks tops. get to it.
  19. #19 Re: Taking forever to warm up
    Topeka, KS
    love this movie.
    What movie is this? I've gotta watch it now! That price is too F**ing high! KABOOOM!
    EDIT: Found it and Downloading now lol !
    Ya OP those prices seem a little high. I'd start with replacing the t-stat yourself 2 bolts simple stuff!
  20. #20 Re: Taking forever to warm up
    its called "used cars" old kurt russel movie.
  1. Pontiacs forever!
    By Frostman in forum Introductions/Noob Questions
    Last Post: 09-08-2011, 09:22 PM
  2. Feels like FOREVER!
    By GTPontiacMan in forum Introductions/Noob Questions
    Last Post: 09-05-2011, 07:55 PM
  3. Tranny taking forever to shift from 2-3 and 3-od
    By kenizzle36 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2011, 12:36 PM
  4. Done with the 3.8 FOREVER
    By KwazrollinZ28GTP in forum The Rant Forum
    Last Post: 05-13-2011, 01:53 AM
  5. Taking this bad boy apart anyone know how?
    By Alman in forum General Tech Discussion
    Last Post: 12-01-2010, 08:39 PM
