Thread: Which gauge pods are you using?
Results 1 to 20 of 33
Gasnmyveins Which gauge pods are you... 12-08-2011, 02:52 PM
MoarkatsINmuhtrailer Re: Which gauge pods are you... 12-08-2011, 02:55 PM
PurpleGuy Re: Which gauge pods are you... 12-08-2011, 03:12 PM
MoarkatsINmuhtrailer Re: Which gauge pods are you... 12-08-2011, 03:14 PM
triebenbach07 Re: Which gauge pods are you... 12-08-2011, 05:07 PM
Wotgtp Re: Which gauge pods are you... 12-08-2011, 05:13 PM
Gasnmyveins Re: Which gauge pods are you... 12-08-2011, 05:17 PM
Wotgtp Re: Which gauge pods are you... 12-08-2011, 06:01 PM
z3r0 Re: Which gauge pods are you... 12-08-2011, 09:47 PM
Gasnmyveins Re: Which gauge pods are you... 12-08-2011, 11:45 PM
Fivefingerdeathpunch Re: Which gauge pods are you... 12-08-2011, 11:49 PM
Gasnmyveins Re: Which gauge pods are you... 12-09-2011, 11:29 PM
MoarkatsINmuhtrailer Re: Which gauge pods are you... 12-08-2011, 09:52 PM
matt5112 Re: Which gauge pods are you... 12-08-2011, 11:57 PM
triebenbach07 Re: Which gauge pods are you... 12-09-2011, 12:35 AM
triebenbach07 Re: Which gauge pods are you... 12-09-2011, 12:38 AM
z3r0 Re: Which gauge pods are you... 12-09-2011, 06:41 PM
DanPrixGTP Re: Which gauge pods are you... 12-09-2011, 03:42 PM
matt5112 Re: Which gauge pods are you... 12-09-2011, 09:43 PM
Gasnmyveins Re: Which gauge pods are you... 12-09-2011, 11:26 PM
z3r0 Re: Which gauge pods are you... 12-09-2011, 11:27 PM
redlinepontiac Re: Which gauge pods are you... 12-10-2011, 02:17 AM
Gasnmyveins Re: Which gauge pods are you... 12-11-2011, 10:04 PM
twol8uluz Re: Which gauge pods are you... 12-11-2011, 03:50 PM
DanPrixGTP Re: Which gauge pods are you... 12-11-2011, 06:20 PM
z3r0 Re: Which gauge pods are you... 12-11-2011, 07:08 PM
z3r0 Re: Which gauge pods are you... 12-11-2011, 07:36 PM
twol8uluz Re: Which gauge pods are you... 12-11-2011, 08:43 PM
Wotgtp Re: Which gauge pods are you... 12-12-2011, 12:02 AM
brandonl2000 Re: Which gauge pods are you... 12-12-2011, 12:05 AM
Fivefingerdeathpunch Re: Which gauge pods are you... 12-12-2011, 12:09 AM
brandonl2000 Re: Which gauge pods are you... 12-12-2011, 12:12 AM
DanPrixGTP Re: Which gauge pods are you... 12-12-2011, 03:30 PM
  1. #1 Which gauge pods are you using?
    Nov 2011
    S Fla
    I'm getting an aeroforce interceptor soon, and will need a pod for it. I don't have a clue who makes good ones that fit well and look good vs who makes merely mediocre (or worse) pods. I'm leaning towards a hud pod, just because it's right there in my line of sight.
    Opinions?
    Black 2000 GTP. Replaced plugs, wires, maf, IAC, tires, tie rod ends, and s/c oil. Lifetime alignment. No mods yet, just got it. Straightening everything out first. 128,xxx miles
  2. #2 Re: Which gauge pods are you using?
    Ohio
    zzp
  3. #3 Re: Which gauge pods are you using?
    Never Never Land
    I'd go for a HUD pod. I plan on ordering one. ZZP's a-pillar pod looks ok too. Supposedly the only one that doesnt screw on and just snaps on.
  4. #4 Re: Which gauge pods are you using?
    Ohio
    yeah i love zzps. need to cut a hole for a hud on mine
  5. #5 Re: Which gauge pods are you using?
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    I got the A-pillar pod from ZZP for 40% off on black friday. It looks great and is a super simple install.
  6. #6 Re: Which gauge pods are you using?
    Mullet Member Wotgtp's Avatar
    Connecticut
    I'm rocking the HUD pod. Love it.
  7. #7 Re: Which gauge pods are you using?
    Nov 2011
    S Fla
    I wish I had known back then that I would be buying this. I could have saved on the pod, and maybe on the gauge, too.
    Do the zz hud pods fit well, and does the color match well? I'd like it to look like a factory install, if I can.
  8. #8 Re: Which gauge pods are you using?
    Connecticut
    Mine is black, and it has a tab that slides between the pillar and the dash.
  9. #9 Re: Which gauge pods are you using?
    Bunnell, FL
    ^^^ pics?
    I'm a Sex Offender
  10. #10 Re: Which gauge pods are you using?
    Nov 2011
    S Fla
    Quote Originally Posted by z3r0 View Post
    ^^^ pics?
    X2. I'd love to see pics of this installed.
  11. #11 Re: Which gauge pods are you using?
  12. #12 Re: Which gauge pods are you using?
    Nov 2011
    S Fla
    Thanks for the pic. That helps a lot. It's easy to think you know how something will look, but you just don't know until you actually see one. I think I'm probably going to get that one.
    I'm still not sure how it attaches, though.
  13. #13 Re: Which gauge pods are you using?
    Ohio
    i saved myself the 10 bucks and painted it tan myself. and it matches the original a pillar panel color perfectly
  14. #14 Re: Which gauge pods are you using?
    terrible fit.
    but what part of our interior isn't?
  15. #15 Re: Which gauge pods are you using?
    Dec 2010
    long prairie, mn
    im smiled @ the wing on the alero
  16. #16 Re: Which gauge pods are you using?
    Dec 2010
    long prairie, mn
    the color on the zzp pillar matches perfectly. the texture is a very near match, close enough u really cant tell unless u hold it next to the oem
  17. #17 Re: Which gauge pods are you using?
    Bunnell, FL
    terrible fit.
    I'm a Sex Offender
  18. #18 Re: Which gauge pods are you using?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    i got my pod from PFYC, it screws on and i dont like it. actually didnt screw it on, i super glued it on because i was scared of screwing down on the wires, but now it looks awful, and i was a noob when i got my pod. go with ZZP pod
  19. #19 Re: Which gauge pods are you using?
    Yeah, that entire piece in my car bounces around because i've broken around half of the pins on it because i've had to resolder the photoelectric resistor in my HUD so many times.
    And guess what, its failing again.
    Which probably means i failed or GM failed when they made my car.
    I wonder which is more likely
  20. #20 Re: Which gauge pods are you using?
    Nov 2011
    S Fla
    Where'd you get that? With all the searching I've been doing for gauge pods, this is the first time I've seen that.
  1. Gauge Pods
    By Dawings33 in forum 04+ Specifics
    Last Post: 04-15-2011, 11:30 AM
  2. gauge pods
    Last Post: 03-20-2010, 01:21 AM
  3. gauge pods
    Last Post: 06-18-2009, 12:55 PM
  4. Gauge Pods
    By blkgp2000 in forum General Tech Discussion
    Last Post: 11-21-2008, 06:30 PM
  5. Gauge pods for 04+ GP's
    By Kyle650 in forum Off Topic Discussion
    Last Post: 03-08-2008, 12:31 PM
