Thread: 3.8 n/a running hot and cutting off
Results 1 to 10 of 10
  1. #1 3.8 n/a running hot and cutting off
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    a friend just wrote me on facebook asking about his park ave running hot and cutting off... what does that sound like to yal. but he has a new thermostat
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: 3.8 n/a running hot and cutting off
    St. Louis
    Well, the running hot could be that he needs to correctly bleed the cooling system since he just replaced the thermostat.
    The shutting down could be a number of things. Does he notice if the tach drops to zero before shutting down? Kinda thinking crank position sensor on this one.
  3. #3 Re: 3.8 n/a running hot and cutting off
    brunswick
    i looked at the car earlier today.. i seen the orange lookin spot under the intake... where the water is coming from when its running hot.. and i think he just needs a tune up... the spark plugs rusted ... smh ppl not taking care of they shi*
  4. #4 Re: 3.8 n/a running hot and cutting off
    Water shouldn't come up when the car runs hot. That's not tune up related.
  5. #5 Re: 3.8 n/a running hot and cutting off
    St. Louis
    Quote Originally Posted by GTPSHAWTY View Post
    So you took a look and found orange Dexcool coming from around the intake? Where abouts on the intake is it leaking? My guess would be around where the TB is.
    And yes, plugs/wires need to be changed as well, but that won't solve the overheating issue. Methinks it's time for LIM gaskets and possibly a new UIM, but not knowing the year it's only a guess.
  6. #6 Re: 3.8 n/a running hot and cutting off
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Compression test before you start replacing gaskets to see if the heads need addressed.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  7. #7 Re: 3.8 n/a running hot and cutting off
    brunswick
    1998 buick park ave.. with 3.8.. dexcool coming from the back of backside by the tb and intake.. residue goes from intake to transmission.. he just asking me to fix the car my quess when i seen it was intake gaskets and waterpump.. also a tune up cause the plugs are shot and the wires probably are too... he has a new tstat and radiator.. any other ideas... idk where to get a compression tester from...
  8. #8 Re: 3.8 n/a running hot and cutting off
    Ohio
    i think the egr tunnel blew out. going into the lim and coming out the sides
  9. #9 Re: 3.8 n/a running hot and cutting off
    brunswick
    how would that even happen?
  10. #10 Re: 3.8 n/a running hot and cutting off
    Quote Originally Posted by Moar Cats In Muh Trailer View Post
    It leaks internally, not externally. Although it could leak from the tube if it's not sealed or is cracked, once the car is turned off. You would have to be burning a lot of coolant for this to be happening though.
    External leaking in this case would more likely be a TB gasket
  1. Cutting the bumper on your struts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 06-16-2011, 01:11 PM
  2. cutting out under a load
    By re209 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2011, 02:02 PM
  3. radio cutting out
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-26-2010, 01:25 AM
  4. ses codes and car cutting out
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 12:33 PM
  5. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
