Thread: Steering/Voltage Issue?
Results 1 to 4 of 4
  1. #1 Steering/Voltage Issue?
    SE Level Member mlasnoski's Avatar
    Jun 2010
    Marquette, Michigan 49855
    Hey Guys,
    Perhaps one of you out there has had a simliar issue. I own a 04 gtp comp g with 113,000 on the clock. This problem doesn't occur all the time, but a lot of the times I can make it do it.
    Problem: when im in drive and I'm turning into a parking spot as I'm turning the wheel the car bogs down like its going to stall out. Once I stop its like the alternator catches back up and is fine. It's never stalled out, but I did observe the battery voltage on the DIC. it would go from a solid 14.70-15 down to a 10 or a 11 volts.
    Any ideas as to why me turning the steering wheel is causing it to bog out. I have a brand new battery in her and voltage is fine. she runs a solid 14.30-15 =)
    Thanks Everyone!
  2. #2 Re: Steering/Voltage Issue?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    mine does it to, ecspecially when its cold. i can hear it kind of "bog" the motor down. idk what it is.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: Steering/Voltage Issue?
    SWPA
    I don't know how it works on a GP, but on other cars there is an idle air controller that is supposed to make the revs go up when you turn the wheel. It may have gone bad, or the connector may have come off the pressure sensor on the pump.
  4. #4 Re: Steering/Voltage Issue?
    Grand Rapids, MI
    yeah mine does the same thing. and it did it on my 99GT as well. i mean it'll rev itself back up and be fine when i turn the wheel. it only does it if you're not moving. but if you're steering and not moving it tends to really put a strain on it.
    so good question
  1. steering issue
    By macjns25 in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2011, 01:17 PM
  2. Power steering issue
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2011, 10:57 AM
  3. power steering issue
    By tstaller2005 in forum General Tech Discussion
    Last Post: 04-27-2011, 10:05 PM
  4. Power Steering Issue
    By dagger in forum General Tech Discussion
    Last Post: 11-13-2009, 09:06 PM
  5. Power Steering Issue?
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2009, 04:09 PM
