Thread: 2001 GTP Supercharged what can I use
Results 1 to 19 of 19
  1. #1 2001 GTP Supercharged what can I use
    Feb 2010
    TN
    Hello guys I was in the local pull a part and found a 2001 3.8 supercharged GTP. I have 1997 Grand Prix GT N/A what on that engine (aside from the supercharger) can I direct swap to mine that is better than the stock parts I have? I mean is the cam better, Throttle body? Sway bars solid or bigger? What can I use. Also I do not want to supercharge mine but I can get the supercharger for $60.00 can I sell that easy enough on the forum as is and maybe double my money plus shipping? Car was junked because is it is locked up and can not be started. Going to yard on weds. Any help will be appreciated.
  2. #2 Re: 2001 GTP Supercharged what can I use
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    only thing that is somewhat identical is the TB, crank,cam valvecovers and exhaust. everything else is different but not necceasarly any better. not sure of suspension.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: 2001 GTP Supercharged what can I use
    Feb 2010
    TN
    Quote Originally Posted by BlackGT97 View Post
    So no point swapping stuff then huh I was looking for some kind of improvement over what I got.
    Thanks
  4. #4 Re: 2001 GTP Supercharged what can I use
    Jul 2011
    Michigan
    i dont know everything, so wait until one of the senior members comeby the thread
  5. #5 Re: 2001 GTP Supercharged what can I use
    Jul 2011
    Michigan
    or....pull the trans, supercharger, lim, heads, HB,fuel rail, TB and then supercharge the 97
  6. #6 Re: 2001 GTP Supercharged what can I use
    Feb 2010
    TN
    Don't want to supercharge mine its got $300,000 miles on it I can see that being too much stress on it plus I am getting 28 mpg right now which I like, but thanks anyway for the thoughts
  7. #7 Re: 2001 GTP Supercharged what can I use
    You really should read the top swap thread.
    http://www.grandprixforums.net/top-s...info-7763.html
    TB's are different, VC's are different.
    crank, cam, and exhaust are the same.
    If you want to talk differences, heads, cam gear, balance shaft, flex plate, LIM, UIM (supercharger), MAP, injectors.
    Suspension is all worn thus basically the same or worse.
    Quote Originally Posted by Logan541 View Post
    Thanks
    Your transmission will not take to additional power. Leave it stock.
    See above.
    Especially the transmission.
  8. #8 Re: 2001 GTP Supercharged what can I use
    Jul 2011
    Michigan
    whats different about the VC's?
  9. #9 Re: 2001 GTP Supercharged what can I use
    n/a heads are different from s/c heads, you need the matching vc for the heads, the injectors for the l67 are in the head, not the manifold like the n/a motor.
  10. #10 Re: 2001 GTP Supercharged what can I use
    Jul 2011
    Michigan
    you could switch the radiators. the gtp should be bigger. and ya, i got that from the top swap thread lol.
  11. #11 Re: 2001 GTP Supercharged what can I use
    Jul 2011
    Michigan
    ya i knew the injectors were in the head, i just thought the Vc would clear them. guess not.
  12. #12 Re: 2001 GTP Supercharged what can I use
    Feb 2010
    TN
    Great thoughts guys but yeah I will not be super charging mine at all just wondering if it would be hard to sell the super charger if I took it. Also just wondering if any real gas mileage or performance gains can be had from any parts I could pull and easily swap over. But never though about the extra power straining the trans. So porting my throttle body and stuff like that would not be advisable either I assume? I am the original owner and car has been well maintained if that helps. Any other parts I could sell easy worth taking? Like I could get the super charger for $60.00 and heads for $30.00 each? I am going to check that top swap link now and I will definitely pull the radiator
    Thanks appreciate the help
  13. #13 Re: 2001 GTP Supercharged what can I use
    Jul 2011
    Michigan
    well...the trans is a whole other argument. im going to refer you to this thread and you can decide for yourself. remember, read the whold thread including the 2 links i posted.
    http://www.grandprixforums.net/98-gt...ted-54586.html
    i plan on supercharging my 97 with the same trans you have...not nearly that kind of milage though.
    and switching the radiator really wouldnt give you any gains. but if you want it, do it and dont let us tell you not to.
  14. #14 Re: 2001 GTP Supercharged what can I use
    Feb 2010
    TN
    oh I know the radiator will not net any gains but figure if I can get it to run even a bit cooler it could not hurt, plus since its the original radiator with that many miles on it how much longer before it fails. It should be a quick and easy swap with no mods needed if I figure right
  15. #15 Re: 2001 GTP Supercharged what can I use
    different years used different tranny cooler fittings.
  16. #16 Re: 2001 GTP Supercharged what can I use
    Feb 2010
    TN
    hey if I swap the 1997 GT Radiator for the 2001 GTP will my fans fix ok or do I have to take those as well?
  17. #17 Re: 2001 GTP Supercharged what can I use
    99+ fans are better IIRC.
  18. #18 Re: 2001 GTP Supercharged what can I use
    Feb 2010
    TN
    Really? Whats the diff?
  19. #19 Re: 2001 GTP Supercharged what can I use
    i think they're just thinner, possibly better shrouding.
    Otherwise probably the same in overall performance.
  1. supercharged
    By v8teezr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2011, 11:16 PM
  2. 2001 3.8 supercharged grand prix stalls
    By reggis in forum General Tech Discussion
    Last Post: 09-26-2010, 11:04 AM
  3. cable connection diagram for 3.8l supercharged 2001
    By fritzie001 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2010, 09:38 AM
  4. 2001 GTP Trans into 2001 SE?
    By TechSmurf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 07:11 PM
  5. me vs. supercharged cav
    By boosting98 in forum Track Sessions and Kills
    Last Post: 05-03-2008, 12:32 AM
