or....pull the trans, supercharger, lim, heads, HB,fuel rail, TB and then supercharge the 97![]()
Don't want to supercharge mine its got $300,000 miles on it I can see that being too much stress on it plus I am getting 28 mpg right now which I like, but thanks anyway for the thoughts
You really should read the top swap thread.
http://www.grandprixforums.net/top-s...info-7763.html
TB's are different, VC's are different.
crank, cam, and exhaust are the same.
If you want to talk differences, heads, cam gear, balance shaft, flex plate, LIM, UIM (supercharger), MAP, injectors.
Suspension is all worn thus basically the same or worse.
Your transmission will not take to additional power. Leave it stock.
See above.
Especially the transmission.
