Thread: 2001 3.8 supercharged grand prix stalls
Results 1 to 14 of 14
  1. #1 2001 3.8 supercharged grand prix stalls
    ky
    at different times while driving. It does seem like it does stall when letting off gas. No codes have been sent. Need help
  2. #2 Re: 2001 3.8 supercharged grand prix stalls
    you CPS(crank positon sensor) is bad, its common problem. They pretty easy to replace with the right tools.
    http://www.grandprixforums.net/crank...ement-698.html
  3. #3 Re: 2001 3.8 supercharged grand prix stalls
    Willoughby, Ohio
    or MAF sensor is bad, does your TSC light come on? does it idle rough? do the RPMs drop to 0 suddenly while driving?
  4. #4 Re: 2001 3.8 supercharged grand prix stalls
    ky
    no lights come on, no codes given as it just quits running. letting it sit from 3 minutes up to 20 minute it will restart.
  5. #5 Re: 2001 3.8 supercharged grand prix stalls
    Willoughby, Ohio
    no codes means no MAF, so CPS is a possibility, do your hear your fuel pump priming?
  6. #6 Re: 2001 3.8 supercharged grand prix stalls
    ky
    no cannot hear fuel pump priming when turn key on even when running good.
  7. #7 Re: 2001 3.8 supercharged grand prix stalls
    ky
    Someone told me if the tach needle moved while trying to start engine then it wasn't the crank sensor, i don't know
  8. #8 Re: 2001 3.8 supercharged grand prix stalls
    ky
    I will check for fuel pump primimg out again tomorrow.
  9. #9 Re: 2001 3.8 supercharged grand prix stalls
    Willoughby, Ohio
    when you put the key to ON before you crank then engine you should hear the fuel pump whine comming from the underside of the car...if you dont you may have found your problem
  10. #10 Re: 2001 3.8 supercharged grand prix stalls
    Willoughby, Ohio
    CPS can work and not work randonly so it is hard to tell, if the tach is dropping to 0 suddenly and the TSC light come on thats a sign of the CPS failing
  11. #11 Re: 2001 3.8 supercharged grand prix stalls
    ky
    Thanks very much for your input as i will drive the car more and see what i can catch when it stalls.
  12. #12 Re: 2001 3.8 supercharged grand prix stalls
    Willoughby, Ohio
    sounds good, keep us posted
  13. #13 Re: 2001 3.8 supercharged grand prix stalls
    ky
    Installed new crank sensor and so for it ran fine today with no stalling.
  14. #14 Re: 2001 3.8 supercharged grand prix stalls
    Willoughby, Ohio
    awesome man
  1. Plz Help V6 3.1L 1996 grand prix car stalls ...tried..nothing working plz..thanks
    By derekcebula in forum Introductions/Noob Questions
    Last Post: 03-10-2013, 04:55 PM
  2. 3800 supercharged.. grand prix
    By fritzie001 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2012, 04:38 AM
  3. 05 grand prix - not supercharged
    By cdutile in forum General Tech Discussion
    Last Post: 12-15-2009, 01:15 PM
  4. grand prix starts, will not idle, stalls.
    By ibanez0110 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 01:20 PM
  5. Okay can you drift a 98 grand prix supercharged?
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2008, 07:57 PM
