Thread: Possible fuel pump issue.
Results 1 to 17 of 17
  1. #1 Re: Possible fuel pump issue.
    Nov 2011
    PHX
    Check to see if the fuel pump resistor has gone out.
    Mine just did. Car will start, run for a second, then die.
    I can keep it running if I keep the RPM's up, but it will not idle.
    Troubleshooting guide
    Check to see if it will run without the resistor and the line straight shorted. It's worth a try.
  2. #2 Re: Possible fuel pump issue.
    I'd check the resistor, although yours didn't fail in the "typical" way. It's worth bending one pin on a relay to know for sure.
    If it's not that..it really sounds like all this freaky warm/cold/warm/freezing/hot/cold weather may have put some condensation in the fuel tanks at your station. I'd pop a can of dry gas in and see if that helps.
  3. #3 Re: Possible fuel pump issue.
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    I will check the resistor by bending the tab....and a can of dry heat sure wont hurt. Does anyone know if the fuel pumps are the same in the GS and the GTP. All the websites show a diff number. I was just wondering why??
  4. #4 Re: Possible fuel pump issue.
    Dec 2010
    Cincinnati, Ohio
    bump
  5. #5 Re: Possible fuel pump issue.
    I only know that when I called on a pump for my 00 GS I was told that there were two versions used in 00 GS. So you had to pop the cover on the hatch and see what the sticker said or run it through your dealer via vin number
  6. #6 Re: Possible fuel pump issue.
    Dec 2010
    Cincinnati, Ohio
    Going to try to get the relay looked at later when I have time, and the drop in pump from wbody store
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Help with an oil problem and fuel pump issue
    By deathjunior in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-28-2011, 11:23 AM
  3. No power to fuel pump relay from PCM? *Update issue resolved*
    By txslow6 in forum General Tech Discussion
    Last Post: 08-10-2011, 09:23 AM
  4. Fuel Pump Issue
    By zildjian102 in forum General Tech Discussion
    Last Post: 12-08-2010, 04:17 PM
  5. Fuel Pump/Resistor issue
    By Pshnmeawy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 07:51 PM
