Hello community! Hope this is in the right place. Just replaced both headlamp assembly because the passenger side cover was cracked and both looked old. I ordered them from TKO Auto Parts through Amazon. TKO Auto Parts - and TKO Auto Parts - They came as a pair. Installation was smooth and I disconnected the battery just in case while I installed them. After installation I tested the headlights, high beams, parking lights, and tail lights. Everything worked fine. The next night I was out I turned off my headlights while driving to do something while the car was running and in drive. I tried turning them back on and they would not come on. All other lights still worked including high beams. The car recognized that I had them on but they were still not working. I messed around for 5min turning them on and off with different combinations of high beams on and off and finally they turned back on. Now days later they are acting up again. Sometimes when I start the car they come on like they should. (This is with the switch set to auto). I figured the headlights that came with the headlamp assembly were just junk so I replaced them with Sylvania 9005SU SilverStar Ultra High Performance Halogen Headlights, Pack of 2 Bulbs. Same issue is coming up. I'm thinking its fuse related or perhaps some wire in the steering column. Any help would be appreciated.
Car experience : very limited
