I have had a intercooled m90 setup for a while now. Been happy with it other then it heat soaking horribly at the drag strip / in traffic. What I noticed is that the heat exchanger up front would get to 140+ degrees on 80 degree days. This obviously hurt the performance of the intercooler and would cause inconsistancy all the time depending on how heat soaked it was. The interstate was never a problem because there was plenty of airflow. After doing a bit more research I found that people consistently saw a huge improvement by adding fans to the heat exchanger. I agreed because commanding my regular engine fans on high would help considerably. So I did the only logical thing and added them!
My personal requirements.
  1. Cant run non stop. It wastes energy and is annoying. Also kills the fans faster.
  2. Must be able to run automatically when necessary.
  3. Must be able to turn them and the pump on manually to keep the core at ambient temps even with a 212 degree engine heat soaking while the car is turned off in the staging lanes.
Unfortunately nobody makes a affordable intercooler fan controller that I could find at least (And regular radiator fan controllers typically cannot be set lower than 160*) so I opted to trigger my fan relay off of the cars stock cooling fans. This actually works quite well because the fans only run when its A. Really hot outside and B. When im not moving. Sure they also run non stop with the air conditioner but honestly 95% of the time the ac is running its hot enough outside for the cooling fans to need to run anyways.
So I drew up a crude schematic of how to have my auto fans and always running pump along with a manual switch for when im playing racecar.
Then I installed some freakin cool 6.5" fans that are only 2" thick!
Tapped into the stock fan wiring by removing a bit of insulation, twisting, and soldering.
And then wired it all up. It works perfect! Currently its winter so its hard to test in the 10* weather but after idling for 20 minutes the heat exchanger was 40* above ambient. When I plugged the relay back in for my new fans it returned back to ambient automatically with the cars cooling fans cycling... or at least close enough that my temp probe couldn't tell. Im freakin excited to test it out at the dragstrip!
