Thread: Gas Tank Hard to Fill
Results 1 to 13 of 13
  1. #1 Gas Tank Hard to Fill
    Aug 2011
    oh
    I have an 04 Grand Prix (not supercharged). I bought it and let it sit for about 6 months. Now the tank is hard to fill--the pump keeps shutting off. I asked a GM dealer about it. I thought it may have a roll over valve in the filler neck. The dealer said it does not but does have a purge valve that is probably stuck on top of the tank. Apparently it vents to the intake. Has anyone experienced this? I don't want to drop the tank without some confirmation that is the problem. I really don't know what else would cause pressure in the tank to keep kicking the gas pump off though.
    Thanks.
  2. #2 Re: Gas Tank Hard to Fill
    Jun 2011
    Are you getting any codes?
    You should check the vent soleniod. Check to see if its clogged.
    Its located in the rear left side. You may have to take off the wheel and cover, its a small hose.
  3. #3 Re: Gas Tank Hard to Fill
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Mine does that at certain pumps in my town...The attendant finally came out and told me not to hold the nozzle so high up; if you can understand what I'm trying to say. I kind of let it rest and it does it much less frequently.
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  4. #4 Re: Gas Tank Hard to Fill
    Aug 2011
    oh
    Quote Originally Posted by E IN v Y View Post
    P0446 which does not tell me much. Vent solenoid differ from the purge valve? Can anyone confirm there is a purge valve on top of the tank? (chevy dealer told me that).
    I disconnected the tube near the filler neck that connects to a canister. There is also a sensor on the canister. No difference with the tube disconnected. There must be another cause than a clogged canister.
  5. #5 Re: Gas Tank Hard to Fill
    Minnesota
    Quote Originally Posted by jeffconnors View Post
    My car is having the same issue. The shop told me (a long time ago) it could be the pressure sensor on the gas pump but I don't think that is it.
    EVAP system in stock form has....The EVAP purge at the front in the engine bay, charcoal canister on the driver side rear behind the tire under the body of the car. There is a sensor connected to the charcoal canister that opens and shuts the purge for the canister. Right now I don't have the front I cut that off and put a little filter on it. I plan on removing the charcoal canister and seeing if I can just spice the two lines together.
  6. #6 Re: Gas Tank Hard to Fill
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    My 05 GMC Jimmy had the same issue a while back. Turned out to be a bad Tank Vent Solenoid. It is a solenoid that when the key is switched to the ON position, the electric solenoid closes the tank vent circuit and the fumes are forced to take a tour through the EVAP system. When the key switch is turned to the OFF position, the solenoid opens the tank vent to allow air to escape for refueling and to de-pressurize the tank when the vehicle sits out in the hot sun all day.
    These cars MAY or MAY NOT be equipped with the same kind of system, but its deff something to look into.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  7. #7 Re: Gas Tank Hard to Fill
    Aug 2011
    oh
    Good info ---thanks.
  8. #8 Re: Gas Tank Hard to Fill
    Minnesota
    Quote Originally Posted by Pure2sin View Post
    That is the same thing I am talking about. There is the canister then the actual sensor (solenoid) the activates the purge. From what I have read you can unplug the sensor so that it will remain open at all times and should cure the problem, although it will set a code if you don't tune it out.
  9. #9 Re: Gas Tank Hard to Fill
    Aug 2011
    oh
    tried upplugging the sensor. Did not work. I don' t want to drop the tank unless I know with reasonable certainty that the purge valve on top of the tank is bad.
  10. #10 Re: Gas Tank Hard to Fill
    Minnesota
    What one did you unplug? The one in the engine bay or the one behind the rear driver side quarter panel by the gas filler neck?
    #1 in this picture:
  11. #11 Re: Gas Tank Hard to Fill
    Aug 2011
    oh
    By the gas filler neck.
  12. #12 Re: Gas Tank Hard to Fill
    Minnesota
    That's a tough one then. I also thought that some years have a vent line connected to the filler neck that can get clogged or rusted.
    The only other thing could be that the EVAP line and/or canister is clogged also but I would think that would throw a code.
  13. #13 Re: Gas Tank Hard to Fill
    Feb 2009
    NE
    I just picked up an 04 last weekend. It is horrible to fuel up. It is so bad I cant even get it to flow constant at the slowest rate while holding the pump handle and it still clicks off. If anyone came to a solution, please post. It is going to be very cold here soon!
  1. how do i fill silencers
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2011, 06:05 AM
  2. How to fill cylinder with air?
    By TheOtherNick in forum General Tech Discussion
    Last Post: 01-15-2009, 11:55 AM
  3. How much Dex 6 to have on hand to fill dry trans?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2008, 01:34 PM
  4. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
