Thread: Gas Tank Hard to Fill
Results 1 to 13 of 13
  1. #1 Re: Gas Tank Hard to Fill
    Minnesota
    Quote Originally Posted by jeffconnors View Post
    P0446 which does not tell me much. Vent solenoid differ from the purge valve? Can anyone confirm there is a purge valve on top of the tank? (chevy dealer told me that).
    I disconnected the tube near the filler neck that connects to a canister. There is also a sensor on the canister. No difference with the tube disconnected. There must be another cause than a clogged canister.
    My car is having the same issue. The shop told me (a long time ago) it could be the pressure sensor on the gas pump but I don't think that is it.
    EVAP system in stock form has....The EVAP purge at the front in the engine bay, charcoal canister on the driver side rear behind the tire under the body of the car. There is a sensor connected to the charcoal canister that opens and shuts the purge for the canister. Right now I don't have the front I cut that off and put a little filter on it. I plan on removing the charcoal canister and seeing if I can just spice the two lines together.
  2. #2 Re: Gas Tank Hard to Fill
    Minnesota
    Quote Originally Posted by Pure2sin View Post
    That is the same thing I am talking about. There is the canister then the actual sensor (solenoid) the activates the purge. From what I have read you can unplug the sensor so that it will remain open at all times and should cure the problem, although it will set a code if you don't tune it out.
  3. #3 Re: Gas Tank Hard to Fill
    Aug 2011
    oh
    tried upplugging the sensor. Did not work. I don' t want to drop the tank unless I know with reasonable certainty that the purge valve on top of the tank is bad.
  4. #4 Re: Gas Tank Hard to Fill
    Minnesota
    What one did you unplug? The one in the engine bay or the one behind the rear driver side quarter panel by the gas filler neck?
    #1 in this picture:
  5. #5 Re: Gas Tank Hard to Fill
    Aug 2011
    oh
    By the gas filler neck.
  6. #6 Re: Gas Tank Hard to Fill
    Minnesota
    That's a tough one then. I also thought that some years have a vent line connected to the filler neck that can get clogged or rusted.
    The only other thing could be that the EVAP line and/or canister is clogged also but I would think that would throw a code.
  1. how do i fill silencers
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2011, 06:05 AM
  2. How to fill cylinder with air?
    By TheOtherNick in forum General Tech Discussion
    Last Post: 01-15-2009, 11:55 AM
  3. How much Dex 6 to have on hand to fill dry trans?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2008, 01:34 PM
  4. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
