Thread: Hitting bumps really hard
Results 1 to 15 of 15
  1. #1 Hitting bumps really hard
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Even little potholes on anything, feels like the cars gonna fall to the ground when it happens..Is this the shocks/springs whatever? Or something else
  2. #2 Re: Hitting bumps really hard
    Omaha, NE
    Why are you hitting bumps and potholes? These are things you need to avoid.
    From your description, it sounds like you have no struts.
  3. #3 Re: Hitting bumps really hard
    Oct 2011
    New Jersey
    Lol i dont mean i'm purposely driving over potholes, i mean like a little rough or bumpy road in my car is like an earthquake beneath you. Sometimes you can't avoid stuff in the road
  4. #4 Re: Hitting bumps really hard
    something is broke. get under your car and find it.
    blown struts would make the ride bouncy, not more jarring.
  5. #5 Re: Hitting bumps really hard
    Chilliwack BC
    sway bar links, control arm bushings, strut moutns, list goes on, look or have it looked at . driveability is the hardest thing to diagnose without hearing or seeing it
  6. #6 Re: Hitting bumps really hard
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    Are you in need of some new tires ????
    04 GT1
  7. #7 Re: Hitting bumps really hard
    Oct 2011
    New Jersey
    ^As a matter of fact, i do need new tires, very soon..Would this be it?
  8. #8 Re: Hitting bumps really hard
    Rubber hardens as it ages.
  9. #9 Re: Hitting bumps really hard
    Oct 2011
    New Jersey
    Alright well i'm sure thats it, theres barely any tread on them either. Thanks guys
  10. #10 Re: Hitting bumps really hard
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Quote Originally Posted by GTLGDP View Post
    I wouldnt count on that being the issue... Worn tires may make the ride a little uncomfortable but from what your describing, you def have some other issue and like the someone already said.. Without any noise or being able to visibly see a broken part, its very hard to diagnose... you might have to play the guessing game and that is costly.
  11. #11 Re: Hitting bumps really hard
    Oct 2011
    New Jersey
    I think i may have exaggerated it a bit. The ride is just not as smooth as my older car used to be (that had brand new tires). Its just a rougher ride
  12. #12 Re: Hitting bumps really hard
    Oct 2011
    Reading PA
    Well thats certainly a good spot to start then since they are worn and need to be replaced anyways.. Hopefully that solves it for you.
  13. #13 Re: Hitting bumps really hard
    PALMDALE CA
    If the tires don't change it , my next guess would be sturts and bushings , try gressing all the nipples too.these are just a guess..
    04 GT1
  14. #14 Re: Hitting bumps really hard
    Oct 2011
    Reading PA
    Quote Originally Posted by PALMCASTER GT1 View Post
    Greasy nipples FTW
  15. #15 Re: Hitting bumps really hard
    PALMDALE CA
    I said it was just a guess , and I know it was spelled wrong but I wasn't gonna repost for one word..
    04 GT1
  1. Rattling going over bumps. And while braking. SOLVED
    By speedy2 in forum Brakes/Suspension/Chassis
    Last Post: 04-28-2011, 04:16 PM
  2. chime when I hit bumps
    By Carbon Summit in forum General Tech Discussion
    Last Post: 12-27-2010, 08:25 PM
  3. Clunking noise over bumps
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2010, 08:26 PM
  4. in need of some bumps
    By 02gtp40 in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2010, 08:31 PM
  5. Squeak when going over Big/Speed Bumps
    By ravi in forum Brakes/Suspension/Chassis
    Last Post: 08-19-2009, 02:01 PM
