Quote Originally Posted by rperry435 View Post
First off theres an HDM solid state module in your under the hood fuse panel (looks just like a relay) its labeled and they are known to go bad. they control drl/headlight function. I'm sure that's your problem.
your other issue with the radio.. the monsoon amp stays on after you get out to allow the door chime to function it is normal. Any other questions just ask. :beer:
Sent from my SPH-L710 using Tapatalk 2
If you are right about my headlight issue being an HDM solid state module - that'd be great, but everything is pointing to the BCM. I cannot identify a relay for the low beam headlights - there are only (4) 10amp fuses for headlights under the hood. Any feedback on which one it is would be greatly appreciated! Thanks.
