Thread: electrical problem??
Results 1 to 4 of 4
  1. #1 electrical problem??
    Nov 2011
    Iowa
    Hi. I have a 2000 grand prix. A couple months ago it wouldn't start. I tried disconnecting the battery and hooking it back up. It starts and runs, but the windows, sunroof, radio, and high fan speed do not work. When I turn the fan speed to high, the radio display and windows work for 2 seconds. Any idea on what could be causing this and what to do about it? Also the ABS and trac light is on all the time. Any input would be greatly appreciated, thanks
  2. #2 Re: electrical problem??
    It's most likely the ignition switch
  3. #3 Re: electrical problem??
    St. Louis
    The ABS and Trac light is probably the result of a bad wheel speed sensor (you will have to replace the wheel bearing to fix this). It is quite common. Have it scanned w/ a reader that can scan for ABS codes and it will tell you which one it is. My Oriellys could not scan for it, had to go to a dealer w/ a TechII.
  4. #4 Re: electrical problem??
    Nov 2011
    Iowa
    ok, will try that. thanks!
  1. Electrical problem
    By rocket69GTP in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2011, 10:29 AM
  2. Electrical Problem!?! Please Help!
    By brandonl2000 in forum General Tech Discussion
    Last Post: 11-28-2010, 12:26 AM
  3. ac electrical problem
    By PrissiePantsGT in forum Audio, Security & Visual Electronics
    Last Post: 09-13-2010, 02:09 PM
  4. Electrical problem
    By jokyfo in forum General Tech Discussion
    Last Post: 08-31-2010, 08:27 AM
  5. Electrical problem
    By black98gt in forum General Tech Discussion
    Last Post: 12-09-2008, 02:02 AM
