Thread: Loose sensor in Intake
Results 1 to 7 of 7
  1. #1 Loose sensor in Intake
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Would this cause i huge problem? I just noticed it today and its really loose...what are you opinions?
  2. #2 Re: Loose sensor in Intake
    Grand Rapids, MI
    that looks like the IAT sensor. as long as its near underhood air it really doesnt matter too much.
  3. #3 Re: Loose sensor in Intake
    Jun 2011
    Detroit, MI
    First of all, it happened becuase thats not a stock intake. And yes it could cause problems, if dust and crap gets sucked in there and ruins your engine. Tape it up or put something to seal it with.
    iLoveSpade
  4. #4 Re: Loose sensor in Intake
    Jun 2011
    Detroit, MI
    Quote Originally Posted by brandonl2000 View Post
    bad
    iLoveSpade
  5. #5 Re: Loose sensor in Intake
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Patch that up a little bit. Not bad so much for the sensor itself, but bad for the fact that the hole can allow unfiltered air to be sucked up and routed directly into your throttle body.. Its not very likely that any time soon something horrible will happen, but id patch it up a little regardless... especially since it looks like that will fall out if you run over a pebble.
  6. #6 Re: Loose sensor in Intake
    Smear some gasket maker around where it should seal up and shove it back in and you shouldn't have to worry about it again.
  7. #7 Re: Loose sensor in Intake
    I'd skip the gasket maker. Grab my step drill and a couple of pcv grommets from the parts store. One will fit the sensor. Then drill the hole to the size for the grommet and insert sensor. All set, nice and clean install.
  1. HELP ! can not get my bolt loose HELP !
    By pughman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2011, 08:11 PM
  2. 98 buick regal air temp intake sensor code
    By Scottydoggs in forum General Tech Discussion
    Last Post: 08-19-2010, 08:20 AM
  3. Hubs are loose
    By Clar2478 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2010, 04:03 PM
  4. Loose Fuse?
    By dagger in forum General Tech Discussion
    Last Post: 05-02-2009, 06:08 PM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
