Thread: Can't remove key
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Can't remove key
    Odessa, MO
    Quote Originally Posted by DunriteDiesel View Post
    its you nuetral safety switch. disconnect it and the car will be fine. the only thing its affects is the light in the gaugu cluster that tells you the gear your in, and the doors unlocking when you put it in park. everything else stays the same
    The nuetral safety switch is located under the shifter and only keeps you from taking your car out of park unless the key is in the on position and your foot is on the brake. It has nothing to do with not being able to remove the key from the ignition. The problem is the Park Lock Solenoid behind the ignition.
    And GrandPrixlbc, if you're genuinely concerned about your passenger reaching over and removing the keys while you're driving.... then you should seriously reconsider who you let in your car in the first place.
  2. #22 Re: Can't remove key
    GT Level Member beastin1's Avatar
    south elgin il.
    Quote Originally Posted by Abrasive View Post
    a-ffn-greed... when i was younger we use to lightly grind down the keys so they could be removed without shutting off the motor... I'd remove the sensor and save some dough....anyone reaches for the key while driving get's the five knuckle sandwich and their walking papers!!!!
    2002 Galaxy Silver 4dr. GTP...supercharger heaven.
    IM ON IT!!!!!!
  1. How to remove the supercharger ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 04:20 PM
  2. FRONT BUMBER [How to remove?]
    By TMOTA503 in forum General Tech Discussion
    Last Post: 07-29-2008, 12:23 AM
  3. how to remove rear speakers ??
    By bayareagtp in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2008, 10:52 AM
  4. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
  5. How to remove the ashtray?
    By IndeedSS in forum General Tech Discussion
    Last Post: 01-20-2008, 06:44 PM
