Thread: How to remove the ashtray?
Results 1 to 10 of 10
  1. #1 How to remove the ashtray?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    So how do you remove the ashtray. Console is out and being painted but not the ashtray yet.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
    Wichita, KS
    If your wanting the whole sha-bang then once the main dash trim bezel is removed, then the ash tray is screwed into the dash much like the radio and HVAC units are. 2 or 3 screws and that sucker is out.
    I don't smoke and don't have a use for it, so I removed my unit all together.
    ~F~
    St Louis MO
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    thanks Jason. I'll pass the info on.
    2010 Camaro SS LS3
    SE Level Member hercman's Avatar
    Marietta, GA
    I use mine as a storage spot but I've seen people pull it out and mount guages there. Pretty clean lookin when done properly.
    1998 GTP
  5. #5 Re: How to remove the ashtray?
    SE Level Member SDGrandPrixGT23's Avatar
    San Diego, California
    Any pics of this removed, I have thought about it as a gauge mounting spot, but still want to utilize the power plug there also.
  6. #6 Re: How to remove the ashtray?
    I live here. UR LOSN's Avatar
    Rockford, IL
    I just put my gauges in under it....
    there are actually 2 gauges in there now...
  7. #7 Re: How to remove the ashtray?
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    I read this and thought....hmmm I have an ashtray? I never once looked for it. I dont smoke. In my other cars, we use the ashtray for change. But the gp has that little spot just right for my change.
    IndeedSS show us pics when your done
  8. #8 Re: How to remove the ashtray?
    Odessa, MO
    I took my ashtray out last night to replace the light bulb. I little more difficult than I thought it would be. I pulled the main dash trim off and sure enough there were 2 screws right in the front holding the ashtray assembly in place. I removed those and figured it would slide right out.... wrong. Still held tightly in place. After some investigating, I spotted two more screws that go in straight up into the bottom of the ashtray assembly back inside the cubby hole. Mine were partially covered enough that I couldn't get a socket or nut driver on them. I used an open end wrench, but once they were out about halfway, they hit the plastic trim of the cubby hole. I ended up having to remove the center trim piece that is the cubby, around the shifter, cup holder, and goes all the way back to the center storage bin. Once I popped it out, there was no problem getting a nut driver on those two to get them out and back in.
    Seemed like a lot of work just to replace a little 194 bulb.
  9. #9 Re: How to remove the ashtray?
    St Louis MO
    Quote Originally Posted by Abrasive View Post
    that does suck, however, thanks for the additional information about the extra two screws.
    2010 Camaro SS LS3
  10. #10 Re: How to remove the ashtray?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i thought there was at least one back there, if not two....
