Thread: Replacing brake line - ABS module to right front wheel
Results 1 to 16 of 16
  1. #1 Replacing brake line - ABS module to right front wheel
    Oct 2011
    london, ontario, canada
    Looking for tips on how to replace steel brake line that goes from brake control module toward right front wheel.
    It follows a path from module downward, bends up over exhaust pipe & then goes downward again & over to bracket on right front side of car 'frame'.
  2. #2 Re: Replacing brake line - module to rf wheel
    Waukesha, WI
    disconnect both ends of the line, pull of the car, bend new piece to match
    its easy, just a p.i.t.a.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: Replacing brake line - ABS module to right front wheel
    Don't post in caps, takes longer to read.
    Please read the thread section description carefully before posting a new thread there. I've moved this thread to the correct section for you.
    Please take the time to type things out fully, especially in thread titles. Makes it easier to understand and easier for others to find this thread later.
    I suggest you follow the instructions posted by redlinepontiac.
    I also suggest coated brake line and a quality flare tool.
    Best of luck.
  4. #4 Re: Replacing brake line - ABS module to right front wheel
    Oct 2011
    I purchased a genuine gm replacement line that is bent as original.
    Do you replace the line from the unserside of the car of from the top side? If from the undersid, do i need to lower the engine cradle to make room?
  5. #5 Re: Replacing brake line - ABS module to right front wheel
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Best of luck.
    i also highly suggest this. it will save alot of headach
  6. #6 Re: Replacing brake line - ABS module to right front wheel
    Waukesha, WI
    more from the side of the car, no you dont need to drop the cradle.
    RayRay
    92 Turbo miata
    02 lexus is300
  7. #7 Re: Replacing brake line - ABS module to right front wheel
    Make sure the fitting on the ABS valve body is not corroded.
    It might strip and then things will get pricey.
  8. #8 Re: Replacing brake line - ABS module to right front wheel
    Oct 2011
    Thanks. Do you mean feed the line from the drivers side of the car, over the exhaust pipe toward the rf wheel & then feed the other end up to the control module. There is no corrosion where the line connects to the ABS module.
  9. #9 Re: Replacing brake line - ABS module to right front wheel
    1. qualtiy double flaring tool is a must
    2. put the ends on the line before you flare.(this one is big)
    3. a tubing bender will help as well as things like coffee can or jar etc to get nice bends.
  10. #10 Re: Replacing brake line - ABS module to right front wheel
    Waukesha, WI
    feed from the pas side to the abs.
    RayRay
    92 Turbo miata
    02 lexus is300
  11. #11 Re: Replacing brake line - ABS module to right front wheel
    He has the OE line from the dealer.
    Quote Originally Posted by SPECIAL EDITION View Post
    Thats good.
    How much did that line run you? Just curious.
  12. #12 Re: Replacing brake line - ABS module to right front wheel
    Oct 2011
    The line is pt 10335973 & comes complete with the insulator & wire protective wrapping. I'm in Canada where things rust!!! list was $71. My GM employee price was 56.80 plus tax.... US prices will be less for sure..
    Still looks like a real problem to install. Has anyone ever actually done this job? I don't think I have received a real descriptive R&R process yet.
  13. #13 Re: Replacing brake line - ABS module to right front wheel
    Waukesha, WI
    ive done it. i bent and flared my line on the car. a lift helps.
    but raise car and support with jack stands.
    remove pasenger side tire.
    unclip line from firewall.
    unbolt line from ABS.
    unbolt line from soft brake hose at clip end.
    feed line out tire well.
    reverse for new line and then bleed line.
    better?
    RayRay
    92 Turbo miata
    02 lexus is300
  14. #14 Re: Replacing brake line - ABS module to right front wheel
    Oct 2011
    I did get the new line in last night. Removing the old line from it's retaining clips was difficult because of where they are. Getting the prebent OEM part installed is impossilbe without bending it out of it's prebent state.
    The fault in the GM design is that the brake line lies next to the insulation on the driver side firewall. The insulation holds moisture that rots the line. Other than that 3" long spot the line looked as new. I did not re-install the clip in this area so the new line does not touch the insulation.
    Thankfully I has access to a 2 post hoist.
  15. #15 Re: Replacing brake line - ABS module to right front wheel
    the line is supposed to have its own sleeve as well.
    It DOES go right over top your downpipe which gets pretty hot.
  16. #16 Re: Replacing brake line - ABS module to right front wheel
    Oct 2011
    Yes, the OEM line did have the insulating sleeve on it as well.... All installed along with fresh rotors & pads & mobil 1 oil change.... 2001 SPECIAL EDITION....
  1. EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    By brandonl2000 in forum How To Write-Ups/Tech Tips
    Last Post: 02-05-2022, 07:51 PM
  2. ss front brake line
    By 04BlackComp_G in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 03:08 AM
  3. Hard brake line ?
    By nvrstsfd23 in forum Brakes/Suspension/Chassis
    Last Post: 07-09-2011, 12:25 AM
  4. ZZP's 5th Stainless Brake Line!!
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 06:06 PM
