Thread: Replacing brake line - ABS module to right front wheel
Results 1 to 16 of 16
  1. #1 Re: Replacing brake line - ABS module to right front wheel
    Don't post in caps, takes longer to read.
    Please read the thread section description carefully before posting a new thread there. I've moved this thread to the correct section for you.
    Please take the time to type things out fully, especially in thread titles. Makes it easier to understand and easier for others to find this thread later.
    I suggest you follow the instructions posted by redlinepontiac.
    I also suggest coated brake line and a quality flare tool.
    Best of luck.
  2. #2 Re: Replacing brake line - ABS module to right front wheel
    Oct 2011
    london, ontario, canada
    I purchased a genuine gm replacement line that is bent as original.
    Do you replace the line from the unserside of the car of from the top side? If from the undersid, do i need to lower the engine cradle to make room?
  3. #3 Re: Replacing brake line - ABS module to right front wheel
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Best of luck.
    i also highly suggest this. it will save alot of headach
  1. EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    By brandonl2000 in forum How To Write-Ups/Tech Tips
    Last Post: 02-05-2022, 07:51 PM
  2. ss front brake line
    By 04BlackComp_G in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 03:08 AM
  3. Hard brake line ?
    By nvrstsfd23 in forum Brakes/Suspension/Chassis
    Last Post: 07-09-2011, 12:25 AM
  4. ZZP's 5th Stainless Brake Line!!
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 06:06 PM
