Thread: boost leak
Results 1 to 11 of 11
  1. #1 Re: boost leak
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i get -19ish at idle and -10 to -14ish while crusing. but i only get 5 psi max on throttle. but during that throttle i just hear the air leaking. what does WOT mean. (without throttle?)
  2. #2 Re: boost leak
    wide open throttle
    any mods?
    and hearing a vacuum leak takes skill or its HUGE, i bet you are just hearing your intake
  3. #3 Re: boost leak
    If your boost pressure is lower than previously... likely the BCS is not allowing the bleed off that allows the BCA to open fully.
  4. #4 Re: boost leak
    one of my friends said the boost solenoid could be going bad, the filter thing is falling apart. i looked online and i cant find any. is there like a special name for it?
  5. #5 Re: boost leak
    Yup..it's a bcs aka Boost Control Soleniod.
  6. #6 Re: boost leak
    GM Typhoon 3-Port Boost Controller Solenoids from HorsepowerFreaks
    thats the one? really expensive for such a little part
  7. #7 Re: boost leak
    Nope. Walk out to your car adn take the part number off yours. Then search on that. It's like $30-40 dealership.
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. Could a small valve cover leak cause a loss of boost on a PCV equipped vehicle?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 11:57 AM
