Thread: Input on Power Window Behaviour?
Results 1 to 10 of 10
  1. #1 Re: Input on Power Window Behaviour?
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    I've seen one and heard that it's common for a motor going bad to stop working while being used....... It's like they have an automatic reset... If something is going wrong they will stop working momentaraly but minutes later will work again.
    We just changed the whole regulator/motor assembly and the problem was solved.
  2. #2 Re: Input on Power Window Behaviour?
    Saraland Alabama
    Quote Originally Posted by crimpton View Post
    usually that is the thermal overload kicking in, a bad connection can cause that as well as a bind, replacing everything would fix that, but may be overkill
  1. power window slash electrical question
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 06-22-2008, 09:25 PM
  2. Power window ISSUES!
    By AR15 guy in forum General Tech Discussion
    Last Post: 06-17-2008, 02:09 AM
  3. Power window parts on ebay?
    By hunter_alexander in forum Off Topic Discussion
    Last Post: 03-07-2008, 01:40 PM
  4. Need Some Input On a GP
    Last Post: 02-22-2008, 07:14 AM
