I doubt the pcm is sending bad info to those items. The car probably wouldn't run right if that were the case.
A pinched wire behind the dash is more likely. Say you put an aftermarket radio in. Maybe it's a bit longer than the stocker and a wire got pinched. That coudl ground out the dic and cause funky readings. Or a rubbed wire, loose connector to the dic.. stuff like that.
the fuel gauge sounds like the sender (common) is starting to go bad.
