Thread: throttle position sensor trouble
Results 1 to 5 of 5
shart throttle position sensor... 10-16-2011, 09:24 PM
BillBoost37 Re: throttle position sensor... 10-17-2011, 05:42 AM
shart Re: throttle position sensor... 10-17-2011, 10:31 AM
tcman49 Re: throttle position sensor... 10-17-2011, 10:41 AM
shart Re: throttle position sensor... 10-17-2011, 11:33 AM
  1. #1 throttle position sensor trouble
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Ok, I need my tps replaced.... obviously I didn't think it would be to hard to do, but I forgot that gm makes everything difficult. I got the special hex bit I need to use, but there is no space to get in at the bottom one straight.. I can only get at it on an angle and it won't grab. To all those that replaced theirs, what tool or method was used? Don't feel like pulling off the whole throttle body.
  2. #2 Re: throttle position sensor trouble
    I use a smeall wrench on a torx bit that would usually go into a screwdriver tip.
    Reading MA? If so..there's someone local that may be able to help you out.
  3. #3 Re: throttle position sensor trouble
    Oct 2011
    Reading PA
    Thanks for the reply. After getting frustrated I started using my head last night. I took a small wrench and glued the bit into it and used that... nothing like making your own tool if you don't have the right one. No, reading PA
  4. #4 Re: throttle position sensor trouble
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    Quote Originally Posted by shart View Post
    what a tool
  5. #5 Re: throttle position sensor trouble
    Oct 2011
    Reading PA
    Lol if u only saw it... I surprised myself with this one. Lol
  1. Throttle Position Sensor
    By apierce1289 in forum General Tech Discussion
    Last Post: 06-07-2011, 09:00 PM
  2. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  3. THrottle position sensor
    By xsvtank in forum General Tech Discussion
    Last Post: 11-27-2010, 07:17 PM
  4. Trouble History With Camshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 06-04-2009, 01:21 PM
  5. Trouble History With Crankshaft Position Sensor
    Last Post: 12-23-2008, 09:43 PM
