Thread: 100k mile mark... things to check/replace?
Results 1 to 5 of 5
  1. #1 100k mile mark... things to check/replace?
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    I recently hit the 100k mile mark and the car is running strong. I've already replaced spark plugs, wires, crank sensor, tps, and both cb axles and tie rod ends. My question... what else should I look at or replace to prevent issues down the road? It's a 2001 gtp. Thanks!
  2. #2 Re: 100k mile mark... things to check/replace?
    I live here. TLSheff's Avatar
    I would check the air filter (wasn't listed in what you've replaced).
    Service the transmission (filter and fluid change, no flush) if you haven't recently.
    Flush the coolant system if its still original and hasn't been changed.
    Change Supercharger Fluid if you haven't done so.
    Other than that, I can't think of anything you should be looking for other than LIM Gaskets if your still on the original plastic ones. If they have been replaced you should be sitting pretty
    Scheduled maintenance is supercharger fluid every 30k, tranny service every 50k, belts every 60k, plugs and wires at 100k or sooner if problem occurs, coolant at 150k but now would be a good time just for records... air filter is as needed, engine oil and filter every 3k, anything else just replace as needed.
  3. #3 Re: 100k mile mark... things to check/replace?
    SE Level Member 313hitman's Avatar
    Oct 2011
    roseville, michigan
    when should the timing dampener and chain be replaced? i just hit 102k
  4. #4 Re: 100k mile mark... things to check/replace?
    Willoughby, Ohio
    Tune up!
    -spark plugs and wires
    -air filter
    -fuel filter
    -coolant flush
    -seafoam to remove carbon build up
    restor all your HP! looks like youve knocked a few off the list and then some already
  5. #5 Re: 100k mile mark... things to check/replace?
    Quote Originally Posted by 313hitman View Post
    99% of the time, never.
  1. So if you had 100k..
    By RegorHtims in forum Off Topic Discussion
    Last Post: 09-14-2011, 11:44 PM
  2. Hello All - 05 GTP just hit 100K
    By KB8URR in forum Introductions/Noob Questions
    Last Post: 02-21-2011, 08:50 PM
  3. Mark
    By MarkUSAF in forum Introductions/Noob Questions
    Last Post: 09-18-2010, 08:11 PM
  4. Cheap modded 97 Grand prix around 100k only $2,500
    By ls6velless454 in forum Midwest
    Last Post: 02-16-2010, 05:16 PM
