Thread: Stalling, PCM fuse blown
Results 1 to 11 of 11
DRock Stalling, PCM fuse blown 10-16-2011, 06:57 PM
BillBoost37 Re: Stalling, PCM fuse blown 10-17-2011, 05:49 AM
DRock Re: Stalling, PCM fuse blown 10-17-2011, 06:18 PM
csssaint12 Re: Stalling, PCM fuse blown 10-17-2011, 09:45 PM
BillBoost37 Re: Stalling, PCM fuse blown 10-18-2011, 05:46 AM
DRock Re: Stalling, PCM fuse blown 10-18-2011, 05:58 AM
DRock Re: Stalling, PCM fuse blown 10-18-2011, 05:58 PM
99PontiacGTP Re: Stalling, PCM fuse blown 10-18-2011, 08:59 PM
BillBoost37 Re: Stalling, PCM fuse blown 10-19-2011, 06:16 AM
  1. #1 Stalling, PCM fuse blown
    Oct 2011
    Kentucky
    Hey guys, Im needing a little help with my 1998 Grand Prix SE. I was driving it last night and it shut off spontaneously. I turned the key off, then back to run. I noticed the fuel pump was making its usual whining sound, but tried to start it with no luck. I had it towed home and put my ez scan. It read "Vehicle Not Responding". I checked and found that one of my ECM fuses had blown, so I replaced it and tried it again. It still read "Vehicle Not Responding". I was wondering if anybody could shed any light on what could be happening. I am really green when it comes to any work with the ECM so the more detailed the better. It has a 3800 power plant. Thanks!
  2. #2 Re: Stalling, PCM fuse blown
    Changed up your title to get you more exposure.
    Did the pcm fuse blow again or is it holding, since you replaced it?
    Take a look for any rubbed or bare wires that might be causing the issue. That's the first steps.
  3. #3 Re: Stalling, PCM fuse blown
    Oct 2011
    Kentucky
    The fuse held. I just took my cold air intake off and saw that the wire were a little worn. I have pictures on my phone if I could figure out how to load them here. My filter looks like it could have some electrical burn to the underside of it.
  4. #4 Re: Stalling, PCM fuse blown
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Quote Originally Posted by DRock View Post
    Get a photobucket account then you can past the IMG code to here and then we can see.
  5. #5 Re: Stalling, PCM fuse blown
    Forget photobucket.. tape up those wires. Then do something to keep your cone filter from rubbing on them again.
  6. #6 Re: Stalling, PCM fuse blown
    Oct 2011
    Kentucky
    The PCM looks burned on top. Like really bad. You dont think that those wires arcing could have fried it do you?
  7. #7 Re: Stalling, PCM fuse blown
    You tell me. Either way, I'd start with the cheapest, biggest, most clearly obvious issue and work my way to the more expensive stuff.
    Fix the rubbed and touching wires, then you'll know more about your pcm.
  8. #8 Re: Stalling, PCM fuse blown
    Oct 2011
    Kentucky
    This is why I come to this forum. Bill, you are great. Thank you. She is running like she always did now. Tomorrow I will buy some looming to wrap the harness in so this doesnt happen again.
  9. #9 Re: Stalling, PCM fuse blown
    Sep 2011
    MI
    Bill is my hero too... he leaves the useless and sarcastic answers to the lesser beings...
  10. #10 Re: Stalling, PCM fuse blown
    Quote Originally Posted by 99PontiacGTP View Post
    You haven't read enough of my stuff. Post up an engine code w/o at least looking up the name. Sarcasm is my middle and last names. I have many many moments of jerkism, most of the time though..those are outweighed by my helpful moments.
  1. Second blown fuel pump fuse in 6 weeks. Help...
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2017, 07:57 PM
  2. Blown fuse(s)?
    By Ricky21 in forum General Tech Discussion
    Last Post: 06-18-2011, 07:32 AM
  3. Blown 3.8
    By Viperkill97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2010, 03:59 PM
  4. blown fuse.
    By backinblackgtp in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2009, 06:28 PM
  5. Fuel Pump Fuse Blown - should I be worried?
    Last Post: 10-28-2009, 09:20 AM
