Hey Guys,
My name is Scott and im a new member here. I bought a 2001 GTP about a month ago. The car is amazing for a used 2001 and it is in great shape. Except.... When im going around 50 and up and i get on the throttle i get a little vibration in the front end. The vibration is mild. I have searched and searched and that helped me check a couple of things. I have replaced both cv axles as they were both completely shot, replaced tie rod ends as they looked to be in bad shape from a visual inspection, got all 4 tires balanced, and just got an alignment. The vibration improved a little from how it was, but it is still there from 50+ and its only while im accelerating.. doesnt matter if its straight or left or right. The car does not pull from side to side or anything and when i brake or let off the gas it is not there at all. I checked the top 2 motor mounts and they appear fine and had a mechanic look at the bottom 2 motor mounts and he said they look fine as well... This isnt a huge deal with the vibration, but its driving me freaking nuts!!! So what do i go after next? Wheel bearings? Control arms? Rack and pinion?! Any ideas on this?
