Thread: How do I remove the throttle cable?
Results 1 to 6 of 6
  1. #1 How do I remove the throttle cable?
    Oct 2011
    Kingsport, TN
    Hello All, I'm a new member and I'm new to the Grand Prix, too. I'm doing an engine swap and I don't know how to remove a throttle cable from a 2000 GTP. Can anyone help me with that? Hopefully, I'm in the right forum section.
    Thanks,
    Jonathan
  2. #2 Re: How do I remove the throttle cable?
    pull it up with your hands then slip it out of the slot it slides into.
  3. #3 Re: How do I remove the throttle cable?
    Oct 2011
    Kingsport, TN
    I've got it separated from the pedal but I don't see how it goes through the firewall.
    Jonathan
  4. #4 Re: How do I remove the throttle cable?
    why are you doing all that?
    You should only have to remove the cables from the throttle body and set them aside and then it will be out of your way when you take the motor out and drop the new one in.
  5. #5 Re: How do I remove the throttle cable?
    Oct 2011
    Kingsport, TN
    I want to make sure I have everything I may need.
    Jonathan
  6. #6 Re: How do I remove the throttle cable?
    Oct 2011
    Kingsport, TN
    I just learned from Pennock's Fiero Forum that I don't need the GTP throttle cable for a swap into a Fiero. The 4-cylinder Fiero cable is the preferred one but the V6 cable can be made to fit.
    Thanks,
    Jonathan
  1. I think i bent my throttle cable mount.
    By Merlin in forum General Tech Discussion
    Last Post: 06-08-2009, 08:18 PM
  2. Please help with power cable for amp
    By blazer2002 in forum General Tech Discussion
    Last Post: 06-05-2009, 05:54 PM
  3. connect throttle cable to pre 99 N* TB
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-30-2008, 10:52 AM
  4. Can I remove the throttle body screen??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 09:00 AM
