Thread: Please help with power cable for amp
Results 1 to 8 of 8
  1. #1 Please help with power cable for amp
    SE Level Member blazer2002's Avatar
    Fremont
    I have a 2000 GP GTP and i was looking for a place to put the amp power cable through the fire wall with out having to drill a hole in it and while still running it through the passenger side of the car. dose anyone know where to run it and have pictures of it
  2. #2 Re: Please help with power cable for amp
    Under the dash on the passenger side...you will have to pull the carpet back but you will see a huge mess of wiring...you can try to get it through there...and it will be right around the power steering pump area engine bay wise.
  3. #3 Re: Please help with power cable for amp
    Fremont
    thanks for the advice ill try looking there
  4. #4 Re: Please help with power cable for amp
    Ohio
    also theres one on drivers side near the bottom of the steering column if you want to run it all the way over there
    00 GTP demodded and forsale
  5. #5 Re: Please help with power cable for amp
    Fremont
    i want to try and keep it on the passenger side so i don't have to run the wire across the engine bay I'm worried about the wire getting melting or something from the heat
    thanks for the advice though.
  6. #6 Re: Please help with power cable for amp
    Dec 2008
    chicago,illinois
    going low on 20"
  7. #7 Re: Please help with power cable for amp
    Fremont
    thanks a lot that like showed me exactly what i needed to do it worked perfect
  8. #8 Re: Please help with power cable for amp
    Ohio
    I had mine run to the drivers side the first time i did it cause i didnt know about the other grommet at the time an it was fine but i def ran it passenger side when i redid it. gives you more wire to work with on the inside which is nice. Good luck w/ the install.
  1. zzp alternator cable
    By Jakegday in forum General Tech Discussion
    Last Post: 05-28-2009, 11:44 PM
  2. run the power cable from battery to trunk - FINISHED!! PICS!
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 03-19-2009, 04:17 PM
  3. power cable from batt
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 12:15 PM
