Thread: just not convinced
Results 1 to 15 of 15
  1. #1 just not convinced
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    bare with me
    -a few weeks ago i got the ses light (after going wot), got it scanned, turns out it was:
    cyl 4 misfire
    #2 o2 sensor bad
    coolant sensor
    iat sensor
    -now yesterday, the light went off. the problem could not have been magically fixed.
    -reecently did a tune up, so that should rule out the plugs and wires for misfire. now i gotta order the vacuume kit from zzp.
    -and on a side note, i have been getting really bad gas milage.
    -what could be the source of the problem (codes and why the light came on then off)?
  2. #2 Re: just not convinced
    If your coolant sensor is bad and the computer thinks your car is only at like 30* it will dump a crap ton of fuel to compensate that may result in a misfire and will give you horrible gas mileage. You could have hit it just right and made it work somehow.
  3. #3 Re: just not convinced
    Jul 2011
    Michigan
    if the coolant temp sensor was bad, wouldnt the gage in the cluster be messed up also?
  4. #4 Re: just not convinced
    not always there is two parts to the sensor one goes to the gauge and one goes to the pcm
  5. #5 Re: just not convinced
    Jul 2011
    Michigan
    will this also explain the o2 sensor issue?
  6. #6 Re: just not convinced
    You never have to worry about the rear o2 unless you have an 01 or newer because they run a diagnostic and will dump fuel until the o2 tells it to shut it off.
  7. #7 Re: just not convinced
    Jul 2011
    Michigan
    thanks for the help, ill probably just replace the temp sensor, its only 20 bucks.
  8. #8 Re: just not convinced
    Hope it works for you.
  9. #9 Re: just not convinced
    Bastard Reptile's Avatar
    Kansas City, MO
    There's only one temp sensor. It tells the gauge via the ppm. If you have a cooler thermostat then it can trip a coolant temp code.
  10. #10 Re: just not convinced
    Are there not some dual senders?
    One signal for the dash, one for the PCM?
  11. #11 Re: just not convinced
    Jul 2011
    Michigan
    Quote Originally Posted by Reptile View Post
    just replaced it with a stock 195
  12. #12 Re: just not convinced
    Kansas City, MO
    As far as I know, the wiring from the sensor goes to the PCM, and that's where it ends, the other one is simply a ground.
  13. #13 Re: just not convinced
    There are three wires in our ECT sensor. One to feed ground or power, two to read the resistance. One of those two feeds to the pcm the other feeds to the gauge.
  14. #14 Re: just not convinced
    Kansas City, MO
    ^^There ya go then. For some reason I was thinking there were only two.
  15. #15 Re: just not convinced
    That's what i was thinking.
