Thread: Long Starts
Results 1 to 16 of 16
  1. #1 Long Starts
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Well, my TPS and torque converter both went out and now I'm having long starts all within like two weeks of each other. The car just cranks forever before the engine fires up. What does that sound like off the bat? Car runs totally fine once started and the battery is fairly new. How hard are the starters to remove/replace on these cars. Mine has 170K miles on it and has never been touched. I'm probably going to tear it out and have it tested at AZ or whatever, but I couldn't find any write-ups or anything. I'm guessing it's at least a semi easy job?
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  2. #2 Re: Long Starts
    If the starter cranks, there's no need to touch it. It's not the problem
    If the engine takes a few cranks to start, then look to what causes an engine to run.
    TPS
    MAF
    IAC
    Vacuum leaks
    Fueling
    Plugs and wires
    If any of these items appear to be in your original post, smack yourself twice for each of them. Because you really didn't say they were fixed, only "out" whatever the eff that means.
    Fix known problems before you ask what could be wrong. Because at this point, I'm pretty sure the biggest issue is located between the steering wheel and seat. lol
  3. #3 Re: Long Starts
    South Jordan, UT
    Hahaha, smart @ss.
    TPS, plugs, wires, are new. MAF is fairly new, and was cleaned about two weeks ago. Fair enough on the starter - I just wasn't sure if the coil could cause my prob or not.
  4. #4 Re: Long Starts
    Plugs are new... new but what brand, what gap, how new?
    Wires?
    Fuel pressure?
    TPS reading?
    MAF reading?
    Any of these things can keep your car from starting. If you add a little throttle does it start?
  5. #5 Re: Long Starts
    South Jordan, UT
    Plugs are AL104's gapped to .055". They have like 3-4K miles on them. Wires are AZ Duralast wires - two weeks old.
    I'll have to get back to you on fuel pressure and MAF reading because I just don't know.
    I'll try the throttle thing too.
    Question - if any of those things you mentioned above were faulty, wouldn't they manifest while driving also and not just starting?
  6. #6 Re: Long Starts
    Maybe..maybe not.
    We can have a sensor for say MAF read very little air, which then turns off the injectors at start up. Hence.. no start. Once running, maybe it's enough air to keep the engine running. But at startup, things need to be in line.
  7. #7 Re: Long Starts
    South Jordan, UT
    Gotcha. K, I'll check out that other stuff when I get a chance. Thanks for the pointers.
  8. #8 Re: Long Starts
    SE Level Member ChrisW2k5's Avatar
    Saskatoon
    What about the CPS? My car also has long start times like yours, and once in a while the tach goes to 0, TCS light comes on, but the car continues to run. I've read on here thats symptoms of a CPS going bad, but would that cause lengthened start times too?
  9. #9 Re: Long Starts
    South Jordan, UT
    I haven't experienced any of those symptoms. Just long starts. It cranks forever and then starts up totally fine without any issues after that.
  10. #10 Re: Long Starts
    South Jordan, UT
    Bingo. Fuel pump was bad (for anyone with similar problems).
  11. #11 Re: Long Starts
    thanks for following up.
  12. #12 Re: Long Starts
    South Jordan, UT
    Sure. I hate it when you're researching and find someone's thread with the exact same symptoms as you and then you never see what the fix/conclusion was.
    Also, thank YOU (and everyone else) for the input on this thread - I appreciate it.
  13. #13 Re: Long Starts
    Welcome. It can be tough to diag over the internet. Glad you did some testing and found it.
  14. #14 Re: Long Starts
    Sep 2011
    MI
    Technicaly the pump probably wasn't bad. The little check valve that keeps the fuel from draining back into your tank was bad. My friends lumina was doing that so he added a button to run/prime the pump without having to crank the engin. Works great... he's cheap.... really cheap...
  15. #15 Re: Long Starts
    South Jordan, UT
    Well as of yesterday the problem went beyond starting. Yesterday the car started dying after being started. New pump and it drives/starts like new.
  16. #16 Re: Long Starts
    FWIW, I find many pump checkballs that are bad and don't always cause issues. When a pump is weak and can't crank the pressure up in the system quick enough, that trick your buddy used will help for a while.
    But..sooner or later the pump will likely die. Meanwhile..with a weak pump..is he running lean?
  1. Cranks a little too long but stil starts?
    By ajc549FF in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 01:50 AM
  2. starts without key
    By stlunatics2oo3 in forum General Tech Discussion
    Last Post: 10-23-2010, 04:16 AM
  3. 04 starts then dies
    By oldtruckluvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 08:09 PM
  4. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
  5. Car never starts on first try but always on second try.
    By joshb227 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 07:57 PM
