FWIW, I find many pump checkballs that are bad and don't always cause issues. When a pump is weak and can't crank the pressure up in the system quick enough, that trick your buddy used will help for a while.
But..sooner or later the pump will likely die. Meanwhile..with a weak pump..is he running lean?
