Thread: SC motor swap
Results 1 to 5 of 5
  1. #1 SC motor swap
    GT Level Member kking89's Avatar
    st.louis
    I'm going motor shopping this weekend at local junkyards to get a SC motor , what would have to be done to swap motors I know the displacement is the same on a GT and GTP. But would it be different if i got the motor out of a regal or ultra ? Or just any other 3800 SC motor
  2. #2 Re: SC motor swap
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Grab the PCM form the same car as the SC'ed engine. If you can. Or else you will need a Tune. I'd get one anyway, but that can be done later if you get the PCM from the SC'ed car.
    Lambokit to be built!!!!!
  3. #3 Re: SC motor swap
  4. #4 Re: SC motor swap
    Texas
    3800 S/C is a 3800 S/C. Make sure and get the heads with the engine as the L67 has different Fuel injector placement(in the heads). Also a 97 PCM will only connect to a 97 wiring harness. All I can think of off the top of my head. You will want to grab the wiring harness as well for map sensor etc.
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: SC motor swap
    You want the motor
    Either a harness or the install kit from Intense/ZZP/WBS (it's 2 wires and a map sensor pigtail)
    and a PCM programmed to your vin with an SC engine file on it.
    If you get a motor out of a PA/Bonne you'll need to swap a couple small exterior parts over, like the engine mount etc. Small easy stuff. Yes..any SC motor 96-03 is the L67 motor. I say 96 because W bodies didn't get it first.
  1. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  2. 3rd motor swap in car
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 05:42 PM
  3. Motor Swap
    By Rolling89GPSE in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-26-2010, 05:09 PM
  4. motor swap
    By ericevenski in forum Off Topic Discussion
    Last Post: 02-20-2010, 05:16 PM
  5. NEED HELP: motor swap
    By fst in forum Northeast
    Last Post: 08-27-2009, 08:50 AM
