Thread: Turbo question
Results 1 to 20 of 34
  1. #1 Turbo question
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Hello, I have a 2001 Grand Prix GT. This is my daily driver and my current mods are only a K&N CAI, zzp down pipe with u-bend delete, and a zzp PCM. I can get a turbo its self for a low price. I am wondering what size turbo would be a good fit for my car? I am also wondering what else i need or need to do to the car? I'm looking for big power gains but I don't need to run 12lbs of boost, 5-6 is plenty for me. I'm trying to get an intercooler for it too. I have been trying to do research on it but i cant find much. Thanks for the help
  2. #2 Re: Turbo question
    Donating Users Tengis's Avatar
    Houston
    You cant just buy a turbo and put it on. You need a turbo kit.
    zzperformance.com
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  3. #3 Re: Turbo question
    Nov 2010
    Yes, I know this. I'm trying to piece a turbo kit together. Sorry for the confusion above
  4. #4 Re: Turbo question
    Houston
    You arent going to piece one together unless you buy turbo pipes from someone like ZZperformance or Cartuning.
    Satin Purple 97 GTP
  5. #5 Re: Turbo question
    Nov 2010
    Ok, thank you for the insite. Do u have any recomendations on the size of turbo?
  6. #6 Re: Turbo question
    Houston
    With what you want to do it doesnt really matter. You could probably run just about any turbo.
    Satin Purple 97 GTP
  7. #7 Re: Turbo question
    Nov 2010
    But is there a big difference from a big turbo vs a small one? Or a is it just the bigger u go the more boost you can get from it?
  8. #8 Re: Turbo question
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    if you only want 5-6 psi, get a smaller turbo, it will build boost faster compared to a large turbo. and from what i hear, get rid of the zzp pcm, there dangerous.
  9. #9 Re: Turbo question
    Houston
    This forum is so full of ****. ZZP is the largest vendor of these cars for a reason.
    Satin Purple 97 GTP
  10. #10 Re: Turbo question
    Nov 2010
    ok thanks, and i have had my zzp pcm for a month or so and haven't had any problems with it. And my car runs alot better because of it. Ive heard people said they were bad too but they were all having problems right from the start. did u hear about what they do in the long run?
  11. #11 Re: Turbo question
    Jul 2011
    Michigan
    yeah, blow your car up. wait till blue comes across the thread, he will inform ya
  12. #12 Re: Turbo question
    Nov 2010
    oh damn. alright, i hope he sees it soon
  13. #13 Re: Turbo question
    Jul 2011
    Michigan
    there is also a few guys on here running turbos. they will help ya out. you know its an expensive route right?
  14. #14 Re: Turbo question
    Texas
    Quote Originally Posted by jpmiller View Post
    ... and from what i hear, get rid of the zzp pcm, there dangerous.
    See sig. God damn I wish people would quit spewing this garbage.
    Quote Originally Posted by Points70 View Post
    You shouldn't always listen to what people have to say sometimes.
    Really? Hopefully he will post exactly what was in the tune specifically that caused it to be so bad. I have yet to see this posted. All I hear is ZZP PCM is bad your going to blow your **** up! Yet no one can give specifics as to why. Ironic don't you think?
    Quote Originally Posted by Tengis View Post
    X MUTHER****ING 2
    OP you will also need larger injectors and have the computer retuned. If you are supercharged you will need a block off plate. Any other questions just ask.
    85 Corvette
    01 TA
    03 Z06
  15. #15 Re: Turbo question
    Nov 2010
    Ive heard stock injectors are ok if you aren't running a lot of boost? and i am not supercharged. i figured i would have to retune the pcm. And i know they can be expensive, thats why im trying to piece together one to help bring down the cost. is the intercooler a good route to go with the turbo?
  16. #16 Re: Turbo question
    Jul 2011
    Michigan
    im just telling him what i heard about the pcms. i honestly have no expericance with them, but the short time ive been here, ive heard a ton of bad things. so maybe we should start a "zzp pcm pro and con" thread and see what happens.
  17. #17 Re: Turbo question
    Jul 2011
    Michigan
    thread already started. lets see what happens.
  18. #18 Re: Turbo question
    Texas
    Absolutely! Turbos generate tons of heat and blow that heat right into your engine. Think of it like a big blow dryer. You need something to help combat that heat and make the air cooler. Otherwise you will have to run less boost and less timing. Which we know frees up less hp.
    85 Corvette
    01 TA
    03 Z06
  19. #19 Re: Turbo question
    Jun 2011
    Detroit, MI
    Just a suggestion, if you only want 5-6 psi of boost, wouldn't it be more economical to top swap?
    iLoveSpade
  20. #20 Re: Turbo question
    Jul 2011
    Michigan
    yes!!!, i was just thinking the exact same thing. arn;t guys running like 8 or 9 psi with the 3.4 setup?
  1. turbo question.
    By Joe m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2010, 11:28 PM
  2. Turbo set up question
    By SloEvil in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 08:14 PM
  3. turbo question
    By grand2000prixgtp in forum Visual/Body Modifications
    Last Post: 04-16-2009, 07:26 AM
  4. Turbo Question
    By BKA05GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2008, 08:41 PM
