They must have changed something cause neither one of my PCMs did that. One was back in 08 never had an issue. With that ZZP PCM, HAI, 3.4 pulley, 1.9 rockers, 3" dp, SSIC I put down 271hp/325tq.
Timeframe has plenty to do with it. Things change. If you say that you had 5 PCM's where all had the same issue you don't believe they would investigate the problem further. This way future customers wouldn't go through the same headache you did? Especially seeing as though you refered to the Missouri attorney to handle the situation.
I'm still curious as to why you continued using the same company after the issue was still there with the 2nd PCM.
And people think their engine is gonna blow due to the safely modding your car thread. Your comments in regard to ZZP scare people into believing if they use the same company for a PCM then they will have the same issues you did.
