Thread: Little guidance on 2000 gtp
Results 1 to 4 of 4
  1. #1 Little guidance on 2000 gtp
    Jul 2011
    Los Angeles
    Okay so, i have a few questions still in mind, and based on what ive read i cant find an answer that leaves me satisfied so here goes..
    Low coolant light is on- I flushed it with the lower radiator hose, washed and cleaned the overflow case. When i put the flush in, turned the car on, turned the heater on, sit till operating temperature and then drained it.
    Do i have to replace the thermo stat?
    ABS Light is on, i have no idea where to start?
    Backround information: Im second owner. 180k miles. Has been sitting outside for a while before it was given to me.
    What i've done so far that im proud of.
    Fixed HUD (:
    Replaced Coolant Elbow
    Washed The Engine Bay
    Brand New Alternator
    Brand New Battery
    Cold Air Intake
  2. #2 Re: Little guidance on 2000 gtp
    London Ont, Canada
    ABS could be wheel hub.. get it scanned.(abs scanner)
  3. #3 Re: Little guidance on 2000 gtp
    Omaha, NE
    Tstat should be replaced when doing a flush. Low coolant light is probably on from being low... Check it again, once it cycles through the system you lose some. Make sure the overfill has some too.
    ABS is probably from a bad wheel hub.
  4. #4 Re: Little guidance on 2000 gtp
    Coolant light, unless its an overheating one that accompanies your temp gauge, is likely the low coolant level light. There is a sensor in the passengerside of the radiator. Right between the transmission lines. They like to get gunky and cause lights.
    ABS, like stated, wheel hub or wiring to them is the most common .
  1. 2000 GTP info center in a 2000 GT?
    By ZachBW55 in forum Visual/Body Modifications
    Last Post: 06-24-2011, 01:24 PM
  2. PO301 code. Did my research and just need a little guidance.
    By transaman98 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:54 PM
  3. Need help and guidance
    By elmac in forum General Tech Discussion
    Last Post: 03-01-2009, 12:52 AM
  4. Transmission repair guidance
    By cwgruv3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 04:21 PM
