Thread: Any possibility of reusing low mileage LIM gasket?
Results 1 to 8 of 8
  1. #1 Any possibility of reusing low mileage LIM gasket?
    Delaware, OH
    Well I changed my LIM gaskets earlier this year and recently they've started leaking at the rear corner on the crossover side.
    Any chance I would be able to reuse the gaskets and just clean and reseal the rubber end pieces? Don't want to fork out another $80 or so for the gaskets if I don't absolutely have to.
    Already gonna have to replace the rear knock sensor and I'm not looking forward to that one bit.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  2. #2 Re: Any possibility of reusing low mileage LIM gasket?
    Charles City, IA
    I have, mine had less than 200 miles on them tho.
    SMGPFC Two Nipple General
  3. #3 Re: Any possibility of reusing low mileage LIM gasket?
    Delaware, OH
    Quote Originally Posted by TheOtherNick View Post
    Mine have around 5k to 6k.
    No More GTP for me.
  4. #4 Re: Any possibility of reusing low mileage LIM gasket?
    Charles City, IA
    Take it apart and check the oring surfaces and see what they look like.
  5. #5 Re: Any possibility of reusing low mileage LIM gasket?
    Florida
    I reused mine with about 400miles on them...same think, tiny leak at one corner. Tho i didnt pull mine off, i just took the RTV chunk out, and reapplied more.
    If in doubt, it's better safe than sorry.
    And they shouldnt be $80..they should be about $50...hell zzp is only $55.
  6. #6 Re: Any possibility of reusing low mileage LIM gasket?
    Never Never Land
    Have fun with that knock sensor...I changed one..biggest PITA ever. Little tip though....the knock sensor has notches in it and you can stick a 21? wrench up there and turn it till it catches the notches and spin it out like that. That's the only way I could get it out. There's not enough room to actually get anything else up there.
  7. #7 Re: Any possibility of reusing low mileage LIM gasket?
    Crows foot maybe. I'd be able to do it. It's not a ford.
    On the LIM's.. If they are leaking.. you may not have added a blob of rtv before the gaskets went down and after they were in place to all 4 corners. It's a pain to clean them, but if you clean them well, you may get away with it.
    Question to get you to buy the new gaskets. How many times do you want to take it apart to change/reuse the gasket? New gaskets mean you can seal them the first time.
  8. #8 Re: Any possibility of reusing low mileage LIM gasket?
    Feb 2009
    flintnasty MI
    I re-use alum gaskets in any situation... Never had a problem.
    Plastic gaskets are pretty much ruined after a few tanks of gas.
  1. Mileage on LIM gasket
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2011, 02:36 PM
  2. Reusing Oxygen Sensors
    By mechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:44 PM
  3. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  4. Possibility of saving motor
    By FordMan77 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2010, 12:11 PM
  5. Unpowered seats to powered seats? A possibility?
    By GrandPrixFan in forum General Tech Discussion
    Last Post: 09-08-2010, 10:31 AM
