Thread: Reusing Oxygen Sensors
Results 1 to 13 of 13
  1. #1 Reusing Oxygen Sensors
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I would like to get a quick opinion from a couple of people that have removed and replaced an oxygen sensor: Were they reusable after being removed, or did they become damaged? I know that they should be reusable, but I feel a premonition that they may easily break/strip/fail when being removed.
    I have never had to remove an oxygen sensor myself. In the sometime near future, I will be installing headers and I am trying to guage whether it is likely I will need to replace the O2 sensors at that time even if they are functional.
    Thanks.
  2. #2 Re: Reusing Oxygen Sensors
    If you're doing headers you might as well get a new front O2 sensor at the very least.
    My factory O2's threads were kinda messed up when i yanked them at 125 K KM
  3. #3 Re: Reusing Oxygen Sensors
    Pennsylvania
    They're supposed to be a 100,000 mile item. That being said, I can't imagine how you could damage something that withstands the heat and pressures of your exhaust all day.
  4. #4 Re: Reusing Oxygen Sensors
    by dropping it.
    Same goes with spark plugs.
  5. #5 Re: Reusing Oxygen Sensors
    Pennsylvania
    I stand corrected. If you're a butterfingers, this can happen.
  6. #6 Re: Reusing Oxygen Sensors
    Dec 2010
    Canada
    I think I have what I need from this thread. How do I close it, or is that up to the moderator?
  7. #7 Re: Reusing Oxygen Sensors
    mods only
  8. #8 Re: Reusing Oxygen Sensors
    original posters can modify the thread like that as well.
    however, ill leave it open for others to respond at a later date if need be.
  9. #9 Re: Reusing Oxygen Sensors
    Bastard Reptile's Avatar
    Kansas City, MO
    Just putting my .02 in here, if/when you do get a new O2 sensor, get a good quality, like a factory Delco one, seriously.
    I've messed around with tuning for years, and just by swapping these, it can change a tune by a ton. The Delco ones read at a faster rate, which is what you want. I've found out over the years that the Borg Warner, Bosch, and even the mighty Denso read as much as 10% off at times, causing instant lean or rich conditions.
  10. #10 Re: Reusing Oxygen Sensors
    Pennsylvania
    ^ The reason I use only factory sensors
  11. #11 Re: Reusing Oxygen Sensors
    Any experience with NTK?
    They seem to be preferred with SD headers because of their small size.
  12. #12 Re: Reusing Oxygen Sensors
    Kansas City, MO
    I haven't with NTK sorry. Yeah, I remember that clearance is a big issue too, Matt. I had to use a Denso with the Pacesetters, because the Delco was too long, and they ended up destroying it. I guess I should have said "whenever possible". I know it's not talked about much, but I have seen this, and I've got the scans to prove it. Delco factory ones almost look like they read erratic, which is actually a good thing, and others seem to have a smooth peak and valley type scan. This is also a reason people get the......P0133 code? I can't remember the code off hand, but it's mostly associated with just having headers. Partly true, because the sensor is farther down the pipe with headers, but it's still a pain in the arse DTC. It's not the end all discussion, but it's something to think about.
  13. #13 Re: Reusing Oxygen Sensors
    Charles City, IA
    Yeah I only use delco narrow bands.
    SMGPFC Two Nipple General
  1. Oxygen sensor queston.
    By ckrummy in forum General Tech Discussion
    Last Post: 07-31-2010, 07:55 PM
  2. downstream oxygen sensor replacement help!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 08:41 PM
  3. Oxygen Sensor
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-21-2009, 05:44 PM
  4. After cat oxygen sensor installation.
    By English John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2009, 04:48 AM
  5. oxygen sensor
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 06:20 PM
