Thread: HELP! cooling fans not running
Results 1 to 3 of 3
  1. #1 HELP! cooling fans not running
    Sep 2011
    flint michigan
    ok here goes i just bought the car so i dont whats rigged and whats not but my cooling fans are not running. first i already supplied voltage to both fans and they run fine. second i read somewhere that if you unplugged coolant temp sensor your fans should run (they did not ). third i replaced all three relays under the hood and checked fuses under the hood then unplugged sensor again with no results so just to make sure i let it run to about 220 degrees again with no results.
    here is the part i dont understand when i unplug the fan connector hanging on top of the radiator from what i understand the middle two wires should be ground (correct me if i am wrong) and the outside two should be hot. so i checked continuity on the grounds with and without cts connected and got nothing. so do the relays deliver a ground? as for the hot wires i get one that is hot with the ignition key with and without cts connected.
    the only time it overheats is when i am sitting still for 15 to twenty minutes and even then as soon as i take off it cools too 190 almost instantly so with that being sadi i would think the rest of the cooling system is ok.that is all i know so far and i am still waiting on a haynes manual from the part store so if anyone can help me i would be greatly appreciated thank you for your time.
  2. #2 Re: HELP! cooling fans not running
    Sep 2011
    flint michigan
    anybody?
  3. #3 Re: HELP! cooling fans not running
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    did you use the search bar?
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. Cooling Fans Not Working
    By thewaitinggame in forum General Tech Discussion
    Last Post: 09-02-2011, 10:24 AM
  3. cooling fans not running and overheating.
    By gtp40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2010, 07:46 PM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
