Thread: what would cause IPWs to drop randomly when at WOT?
Results 1 to 5 of 5
fst what would cause IPWs to drop... 09-15-2011, 07:33 PM
PurpleGuy Re: what would cause IPWs to... 09-15-2011, 07:35 PM
fst Re: what would cause IPWs to... 09-15-2011, 07:38 PM
FoSHO99 Re: what would cause IPWs to... 09-15-2011, 07:39 PM
fst Re: what would cause IPWs to... 09-15-2011, 07:40 PM
  1. #1 what would cause IPWs to drop randomly when at WOT?
    what would cause the IPWs to drop drastically while at WOT? can rule out injectors as this happened still when i was running 65lb and recently switched to 80lb
    while at WOT my IPWs (running 65lb) would avg 14-15ms but then randomly drop to like 11mS where i would see my WB go from 10.9 to like 12-13AFR and i instantly let off the throttle to save my motor of course lol. with the 80lb it avg 10-11ms and it dropped to 9ms and again WB showed it went lean towards the 12-13AFR mark.
    currently running new 80lb inj, low mileage fuel filter, racetronix 255lph FP, zzp gen 1 fuel pump rewire....im thinking the rewire isnt enough voltage?
  2. #2 Re: what would cause IPWs to drop randomly when at WOT?
    Never Never Land
    Unrelated...you Freemo?
  3. #3 Re: what would cause IPWs to drop randomly when at WOT?
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    yes. u saw my post on FB didnt you?
  4. #4 Re: what would cause IPWs to drop randomly when at WOT?
    Jan 1970
    Maquoketa, Iowa
    If your IPW's are dropping, it's not a fuel starvation issue, it's probably something in the pcm that is telling it to cut fuel. If your IPW's are hitting 24 and it's leaning out then it's fuel deprived.
    Post up a scan on google docs or something.
  5. #5 Re: what would cause IPWs to drop randomly when at WOT?
    i would but the scans in the car ATM. its not even remotely close in hitting 24mS
    edit-and i have the fuel cut increased to like 6700RPMs. the scans via LS1M, which basically is limited on parameters.
  1. Alarm Problems (goes off randomly)
    By hondo in forum General Tech Discussion
    Last Post: 11-08-2012, 05:29 PM
  2. 01 GTP stalling randomly not starting
    By xekrubx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2011, 06:30 PM
  3. Car dies randomly.
    By AnalyzeFaith in forum General Tech Discussion
    Last Post: 02-03-2011, 12:08 PM
  4. car randomly shutting down / DTC codes
    By reallyfast1 in forum General Tech Discussion
    Last Post: 08-08-2010, 05:18 PM
  5. Radio randomly changes stations
    By mattyrz in forum Audio, Security & Visual Electronics
    Last Post: 11-05-2009, 12:48 PM
